Air conditioning
Discussion in '5 Lug' started by netsomnia, Jun 18, 2014.
  1. Jun 18, 2014 at 3:28 PM
    netsomnia
    netsomnia [OP] Well-Known Member
    Central/Eastern Missouri
    1998 2WD Tacoma 5 lug
    How do I add air conditioning?
  2. Sep 20, 2014 at 1:21 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    Roll down the window.
    An air conditioning system needs a compressor, evaporator, condenser, filter/dryer and hoses to connect all the items together.
    If you were to spend some time researching everything you could do it yourself. You would need around $600 in tools to do the job.
  3. Sep 20, 2014 at 2:47 PM
    RustyBucket
    RustyBucket Well-Known Member
    2010 4Cyl 2WD AC
    Also, unless you spend an arm and a leg on new components, you'd be looking at used parts. And, given the quality of the components used in the OEM system, it's questionable how much life is left in the system.
    The compressors in these trucks are made by Delphi, a major supplier to GM and they barely last longer than the warranty.
    *EDIT*
    I see you have a 1st gen: you're in luck, they still used Denso compressors. Toyota cheaped out on the 2005+ 2nd gen.
  4. Sep 22, 2014 at 3:08 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Never heard of this before. Now I know why my A/C works so well. My 1991 Toyota PU's A/C was horrible, took forever to cool the tiny cab. You should not make such blanket statements without providing evidence. If yours failed, I am sorry.
  5. Oct 1, 2014 at 4:09 PM
    netsomnia
    Thank you for clarifying. The cab is so small and I only drove 100 miles round trip for work all Summer. The blower on full blast worked just fine for my commute but in 100 degree weather the stoplights seemed a little longer than usual. :) I decided to do exhaust and engine tuning first - tires and maybe bigger wheels next. Forgoing cold air altogether.
  6. Oct 10, 2014 at 5:01 AM
    RustyBucket
    2010 4Cyl 2WD AC
    You have a good point on making such a statement without evidence to back it up.
    My statement is based upon my own research: When the air conditioing failed on me, I did research to find out where I could obtain replacement parts. This research led me to find numerous threads on several forums where other Tacoma owners had their air conditioning compressors fail in a similar manner, many of them with low mileage yet outside warranty.
    The issue is that there is a part of the clutch pulley that consists of concentric metal and rubber rings. the rubber layer is between the two metal layers and the rubber eventually loses bond with the metal. the rotational force causes the outer layer to disintegrate, thus causing the air conditioning to fail with a howling or wining sound.
    My final annoyance with this situation is that, while it is just the clutch pulley that failed, you cannot easily find the clutch pulley for sale separate from the compressor. The few retailers that do sell it (online dealerships), have the list price for the clutch pulley as higher than the list price for the compressor complete with clutch pulley.
