Air down Goodyear tires
Discussion in 'Wheels & Tires' started by Glockman18, Sep 10, 2018.
  1. Sep 10, 2018 at 11:49 AM
    Glockman18
    Glockman18 [OP] Well-Known Member
    2018 Or
    Anyone air down their stock Goodyear Kevlar tires? If so, what's a good, safe psi?
  2. Sep 11, 2018 at 9:19 AM
    Glockman18
    2018 Or
  3. Sep 11, 2018 at 9:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Having enough pressure to keep the bead seated under the particular condition you are aired down in of course is key.
    Any reason you're thinking that would be a different pressure than any other tire?
  4. Sep 11, 2018 at 9:30 AM
    Glockman18
    2018 Or
    Just curious to know if they are the same toughness as a bfgko2 or wildpeak. Granted they are stock tires and haven't truly tried out the full potential of them yet.
    Didn't know if they could handle 20 psi or so.
  5. Sep 11, 2018 at 9:34 AM
    eon_blue
    Azusa, CA
    An E rated tire's sidewall won't flex as much as a P or C rated tire's will, so they can be safely aired down more without popping off the bead. I air my E rated STMaxx down to 14 or so in most 4x4 conditions, I personally wouldn't go under 20 with a P or C rated tire but that's me. Check the load rating on your tires but I'm betting their either P or C
  6. Sep 11, 2018 at 9:39 AM
    Glockman18
    2018 Or
    Ok sounds good. I had bfg ko2's on another truck and they were E load. That's why I was wondering if anyone had any issues with the oem Kevlar tires when airing down.
  7. Sep 11, 2018 at 1:44 PM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    I had no trouble with about 15-16psi but that was just on beach sand, not rock. I think 20 would be okay for most situations.
