air filter help
Discussion in 'Performance and Tuning' started by image, Mar 16, 2008.
  1. Mar 20, 2008 at 9:26 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Did your ECO work. I believe that the CAi will have gains, its dyno proven. Just looking for the best setup with stock exhaust to keep water out and get better (real life) mpg
  2. Mar 20, 2008 at 9:41 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Yeah, that's why I said you wouldn't see much from any aftermarket filter.
    Dyno proven for what? Only dyno charts I've ever seen were for torque and hp. None of them showed an increase or decrease in mpg. More power almost always = less MPG. Fact of life. Power takes air and fuel. Add more air, and the engine adds more gas. More gas = less mpg.
    Some people may have picked up 1mpg, but can that really be proven to come from the intake? Or is it just due to how they were driving for that tank? Not to mention most intakes cost $300-$400. If you're looking to get it to save money on gas, it's going to be a long time before it pays for itself let alone saves you money. If it would give you and extra 5-10mpg, sure! I'd go for it. But I can get the same increase I've seen mentioned by driving a little more conservatively and that doesn't cost anything.
  3. Mar 20, 2008 at 10:01 AM
    piercedtiger
    Jon
    Southern Tier, NY
    I guess I'm just skeptical of anything claiming only 1 or 2 mpg increases at a cost of $200 or more for the device. My own truck fluctuates that much from tank to tank without changing anything (synthetic fluids, air filter, etc). I've gotten as low as 16mpg during the winter using 4wd several times, and as high as 21 one day on a long trip. That's a 5mpg swing on the same truck with no mods between that would affect mileage. So anything less than a 5mpg increase seems like a waste to me. If that makes sense.
  4. Mar 20, 2008 at 10:49 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Tiger let me put it this way, if I can get an intake that gives me gains in the HP and Torque dept and keeps my mpg the same I'd be happy. That is sorta what I meant earlier, if I can get mpg increase great.
    Being new to the Taco performance intakes, what do you guys recommend for this?
  5. Mar 20, 2008 at 10:57 AM
    piercedtiger
    Jon
    Southern Tier, NY
    I see what you're saying. Keeping the mpg the same (or at least not loosing any) will depend a lot on your right foot! :laugh: My buddy has a K&N on his Ford, and always gets on the gas for the WHOOOOOOMP sound it makes. Then wonders why his mileage sucks. :laugh:
    I don't have experience with any of them myself, but I've read about a few:
    • K&N
    • URD
    • Volant
    • AFE
    and a few others I can't think of now. Some people have bought a K&N and replaced the filter with an AFE (I think. Maybe it was AEM) to get a dry filter to avoid the oil fouling the MAF sensor.
    I just bought an AFE filter today. More because I can wash and reuse it ($50 once instead of multiple $20 disposable filters) than for MPG gains. Should be here in a week I guess so I'll see if it does anything after it goes in. I have a scangauge so I can monitor realtime mpg readings.
    Edit:
    Not to depress you, but I gave up trying to improve the MPG on this truck. People say bed covers help, throttle body spacers help, intakes help, exhaust helps, blah blah blah. No one I've seen has been able to post clear before and after numbers or anything more than a 1-2mpg increase. Seems like it's almost impossible to get more out of these trucks so I stopped trying. I figured a few things here and there, doing 1mpg each and I could get from the EPA estimated 18mpg up to around 25 and be happy. Sadly, nothing I've done has gotten it above 18.5ish. Close to 19, but never 19 for a tank. Most I EVER saw was the 21.something for 1 day during a trip that was 2 hours both ways, and mostly flat. Haven't seen that again though with all the hills here.
  6. Mar 20, 2008 at 11:20 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Thanks for the info...I'll have to search around and get some other inputs. The drop in might be the way to go.
    Did you remove or is there a piece in our wheel wells that can be removed?
  7. Mar 20, 2008 at 11:45 AM
    piercedtiger
    Jon
    Southern Tier, NY
    The stock intake is routed to the wheel well which just has a thin plastic splash guard with slits cut in it to let air in. It's fairly big. The only thing I can thing of an aftermarket intake improving is just a slightly shorter, straight air flow. The stock on seems larger in diameter than most of the other ones.
  8. Mar 26, 2008 at 8:16 PM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    oil it and hang it overnight, then put in truck...Learned it in motocross, works the same in tacomas...............
  9. Mar 26, 2008 at 8:19 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You say that but when you have a vehicle with a weak MAF to begin with, it may (will?) destroy it. My previous car, an '05 Altima 3.5SE was just such an animal. I still to this day believe the MAF failure I experienced was caused by the K&N filter I used. New MAF installed along with an AEM Dryflow, I never experienced another problem. Not scientific, I know, but oiled filters are very old technology, not to mention they don't filter very well anyway.
  10. Mar 27, 2008 at 1:27 AM
    willard417
    willard417 Yeah
    Luke
    beaver county, PA
    06' access cab. 2.7L
    alpine head unit, removed secondary air filter, 18" XD Rockstars. 285/60/R18, 3" OME 884/AAL OME shocks all around.
    would a maf ever need cleaned with the stock filter? like maintanence.
  11. Apr 9, 2008 at 8:25 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    My thoughts: AFE oil free to the door for $44. I figure a OEM filter is at least $20. The AFE filters down to 1 micron with a soap and water clean-up. The stock system has somewhat of a bend but large composite tube with cooler air directly to the thottle body. Beats $300 and having to swap the sensor over. I figure the AFE and removing the secondary probably added 10 HP for less than a $50 bill, super cheap gains. Feels and sounds like it anyway, who knows, I'll never have it on a dyno.
  12. Apr 10, 2008 at 7:01 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Exactly. And I now have an AFE Pro Dry filter on mine. Also seems to have boosted the mpg slightly, but I'm waiting until I've run a few tanks through to see if there's an overall increase.
  13. Apr 10, 2008 at 7:12 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    Bilstein 5100's @ 2.0", Wheelers 1.5" AAL, 265/75/16 Firestone Destination AT2's
    I plan on getting a AFE drop in for my truck. I personaly cant see wasting upwords of $300 buck for an intake thats probably not going to do much at all. Just my .02 :)
  14. Apr 10, 2008 at 7:15 AM
    4x4x4trd
    North Texas
    I used an oiled K&N drop in on my '99 for nine years with no problems at all. But the new oil free ones filter better, clean up with soap and water, and are cheaper as well.
  15. Apr 10, 2008 at 7:19 AM
    #35
    Burns
    17 DCSB Off-Road
    I had a K&N on my 98 Taco and it messed up my MAF and I had to clean it out every so often. Thats why I like the idea of the high flow dry filter.
  16. Apr 10, 2008 at 4:42 PM
    #36
    M2M
    M2M Well-Known Member
    bilstiens, sport 08 w/o scoop, debadged
    so where is this sensor located ?
  17. Apr 10, 2008 at 4:52 PM
    #37
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I4's it's in the top of the air box, near the intake tube.
    V6 is in the top of the air box as well, but not visible untill you remove the fancy engine cover.
    It is held in by two screws, and has a wiring harness coming off of it.
    It is visible in the first picture of the first post on this thread
