Air filter question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigcoffinhunter, Nov 22, 2010.
  1. Nov 22, 2010 at 5:38 AM
    bigcoffinhunter
    bigcoffinhunter [OP] Well-Known Member
    Ok this is going to sound dumb, but how do you get the lid of the air filter box off? I remove the metal clips, and it seems like there are two plastic pieces in the back holding it on. I figured I should ask before I broke something.
    Yes I should read the manual, but I'm not sure where I left it. So I ask you fine folks instead.
  2. Nov 22, 2010 at 6:22 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    If I understand your question correctly, most vehicles you should be able to just remove the two metal clips and then pull the cover towards the clips. ie. not up, but over. I haven't done it yet on my '10 but I'm confident that's how my '99 was and most I've seen are that way. Good luck.
  3. Nov 22, 2010 at 6:24 AM
    bigcoffinhunter
    Ah ok. I was pulling straight up like in my old first gen. Thanks!
