Air filter question...
Discussion in 'Technical Chat' started by MKW, Jan 10, 2008.
  1. Jan 10, 2008 at 2:29 PM
    MKW
    MKW [OP] Well-Known Member
    Murrells Inlet, SC
    2014 RC 4x4
    OME 3" lift MK6 wheels 285 Fierce MTs & 4.88s!!
    I'm sure that somebody has done this, but I've searched and can't find anything.
    Anyway, has anyone simply removed the hose/pipe from the airbox and installed a 4" cone filter where the hose was attached and then removed the factory filter from the airbox??? If so, did it work and did it seem to help the flow??
  2. Jan 10, 2008 at 3:33 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    my guess is that it would make it worse, b/c u'll be pulling in all that heat directly from the engine compartment. the way it is now, its set up to a small type og cold air intake by pulling the air from inside the fender. only thing is that the piping and box and filters are restrictive. i'd do the secondary air filter removal and get a drop in afe dryfilter if u dont wanna drop in all the money for a true cai
  3. Jan 10, 2008 at 3:52 PM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    That's exactly what I was thinking. Where can I get an AFE dry filter??
  4. Jan 10, 2008 at 9:26 PM
    The_Hodge
    SC
    AFE link
    here's the link directly to AFE. its $59.-- before shipping. u can do a search for a toyota tacoma 2006 and it will definately be there, just make sure that you look for the one described "dry S".
  5. Jan 11, 2008 at 4:45 AM
    MKW
    Murrells Inlet, SC
    2014 RC 4x4
    Thanks.............
