Air flow?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chrissteffen599, Sep 15, 2014.
  1. Sep 15, 2014 at 10:24 AM
    Chrissteffen599
    Chrissteffen599 [OP] Well-Known Member
    Texas
    02 tacoma
    Bilstein 5100 all around Allpro front and rear bumpers Trailgear turn signals Hella 700ff HID conversion
    So this isn't a huge problem but id like to know how to fix it if it's a problem at all. So, when my a/c is off air is still coming through the vents even though I have all air turned off including the button that allows external air in. The air flow gets higher and higher the faster I go, (the more wind is put through the front end). Anybody have any ideas?!
  2. Sep 15, 2014 at 10:55 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    Sounds like the flapper came loose. Or maybe it's not closing. Did u stick your head down there and listen to see if you here the servo motor when you hit the vent button?
