Air fuel mods help 3.4 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Paulg443, Jan 28, 2014.
  1. Jan 28, 2014 at 5:44 PM
    Paulg443
    Paulg443 [OP] Active Member
    Paul
    Nipomo California
    04 prerunner sr5 v6
    K&n intake
    Does anyone know of more air/fuel mods for a stock 3.4 v6 tacoma?
    What I have down
    - headers ( port/polish )
    - full exhaust
    - k&n intake
    Is there anything else I can do/add?
    I tried searching the forum but came up with nothing
  2. Jan 28, 2014 at 7:18 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    What are you looking to accomplish first of all? If more power and you have a good amount of money I'd go turbo set up.
  3. Jan 28, 2014 at 7:20 PM
    Paulg443
    Paul
    Nipomo California
    04 prerunner sr5 v6
    K&n intake
    I'm in the waiting for a modded CXRacing turbo kit but for now I just want more air/fuel mods other than a supercharger or turbo.
    No forces induction
    Just free up everything
  4. Jan 28, 2014 at 7:32 PM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    I'm not sure you understand what a port and polish is.
    Whatever you're looking for (power, MPG, etc)...you'll probably get better results from a tune-up and/or replacing worn engine parts than any and all bolt-on "mods" combined.
    The typical "this-will-gain-you-20-horsepower" intake, headers, and exhaust, will not in fact get you any gains. You may possibly be able to get a few horsepower (like 2-3) from a re-tune. You can add bolt-on mods, then get your ECU tuned to compensate for the additional air and fuel flow, and that can help.
  5. Jan 28, 2014 at 8:47 PM
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    Deck plate mod + headers + exhaust will give you power gains. How much? its different for every truck, anywhere from 1 - 20 whp with all 3 installed... throw in some water or water/meth injection and you will get another 10 give or take.
  6. Jan 28, 2014 at 8:53 PM
    fast5speed
    Washington D.C.
    Please upload dyno sheets showing gains.
    I'll wait
  7. Jan 28, 2014 at 11:07 PM
    DSMJRV
    justin
    Corona, CA
  8. Jan 28, 2014 at 11:10 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    No.
    Pretty much nothing. Nothing you spend will be worth the 5hp you gain. You won't even notice it.
    Save up for FAI via Turbo or SC.
