Air fuel ratio on scan guage 2 HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nachotaco, Dec 16, 2017.
  1. Dec 16, 2017 at 6:34 AM
    Nachotaco
    Nachotaco [OP] Well-Known Member
    Jonathan
    Georgia
    Can I show my tacomas air fuel ratio on my scan guage 2 if so how do I set it up? What about fuel pressure? Thanks
  2. Dec 16, 2017 at 7:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    No sensor to monitor fuel pressure, so the gauge won't have anything to display.
  3. Dec 16, 2017 at 8:16 AM
    Nachotaco
    Jonathan
    Georgia
    Thanks! Good to know
  4. Dec 16, 2017 at 9:28 AM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    its odd on that set up.no fuel pressure or oil pressure.
  5. Dec 16, 2017 at 9:38 AM
    Nachotaco
    Jonathan
    Georgia
    So it seems as though i will need to run additional gauges in order to monitor these two items.
  6. Dec 16, 2017 at 9:50 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct.
  7. Dec 16, 2017 at 10:32 AM
    Nachotaco
    Jonathan
    Georgia
    Ah another project. Ill have to do some searching on here for a right up unless someone can point me in the right direction. Thanks @Torspd for the info.
    Torspd likes this.
  8. Dec 16, 2017 at 6:31 PM
    JaxJacket
    JaxJacket Well-Known Member
    2013 DCLB
  9. Dec 16, 2017 at 6:34 PM
    AWilson013
    AWilson013 Almighty Dirt King
    Alex
    Seattle, WA
    2006 GX 470 Sport
    Matte Grey SCS F5s - 255/80R17 ST Maxx - Front Runner Slimline II - CVT Tent/Awning - 35w Morimoto HID Low Beams - LED High Beams - LED Fogs - AFE Dry Filter - BP-51s - Dirt King UCAs
    URD sells a fuel rail tap so you can add a sensor for a fuel pressure gauge.
    https://www.urdusa.com/urd-fuel-rail-tap/
    Also- don't use the scangauge to monitor AF ratio. The refresh rate is garbage, and the read makes no sense 90% of the time.
    I am an AEM UEGO fan, but Innovate gauges are wayyyy easier to datalog with, if that's your jam. Any exhaust shop should be able to weld a bung into your exhaust for the wideband sensor. When I had mine done it was like $35.
    I think URD sells AEM stuff now too, but probably be able to find it cheaper elsewhere.
    Nachotaco[OP] likes this.
  10. Dec 16, 2017 at 6:43 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    To bad Toyota does not monitor Oil pressure. You can tell so much by it if you pay attention to it.
  11. Dec 16, 2017 at 6:49 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
  12. Dec 17, 2017 at 6:01 AM
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    Here's what i used for the A/F set up (i believe)
    Air to Fuel Ratio (True Air to Fuel ratio)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 05BE00800000
    NAM: A/F
    TomTwo likes this.
  13. Dec 17, 2017 at 6:52 AM
    Nachotaco
    Jonathan
    Georgia
    Anyone have any recommendations for mounting options and or gauges? Seems as though the ol scan gauge is not going to do what i need it to do.
  14. Dec 17, 2017 at 8:18 AM
    AWilson013
    Alex
    Seattle, WA
    2006 GX 470 Sport
    I’m a big fan of AEM’s digital gauges but I did have a hard time data logging with them. The innovate gauges are great for that.
    The AEM gauges auto adjust for brightness, obviously all match each other, and are super easy to read.
    I had the Lotek a-pillar pods in my 4Runner and really liked that setup. However, after driving my buddy’s truck with the gauges on the steering column, I kinda prefer that.
    Here are a couple options:
    https://www.urdusa.com/flexpod-gauge-mount-tacoma-2005-2015/
    https://www.perrin.com/shop/interior-gauges/gauge-pod
    Nachotaco[QUOTED][OP] likes this.
