Air/fuel ratio sensors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Switek, Jan 20, 2010.
  1. Jan 20, 2010 at 2:23 PM
    Switek
    Switek [OP] Active Member
    Pelham, AL
    2010 TRD SPORT
    Kenwood DNX5120 Headunit, 12" Kicker sub, Alpine amps, Polk db in all 4 doors, Grillcraft grille, Aires bullbar, PIAA lighting, HID heads and fogs, Circuit boss by Painless Performance, BHLM, Access LE Tonneau
    This bulletin pertains to the air fuel ratio sensors on the following models: 4Runner Avalon Camry FJ Cruiser Highlander Highlander HV Land Cruiser MR2 Spyder RAV4
    Sequoia
    Sienna
    Solara
    Supra
    T100
    Tacoma
    Tundra
    This service bulletin provides information on the proper identification of engine bank 1 and engine bank 2 for correct A/F sensor and oxygen sensor replacement. This bulletin contains information that identifies engine bank 1 and engine bank 2 on the following engines: 1AZ-FE 2AZ-FE 2AZ-FE (PZEV) 1GR-FE 2GR-FE 2JZ-GE 1MZ-FE 3MZ-FE 1UR-FE 3UR-FE 2UZ-FE 5VZ-FE 1ZZ-FE
    You can view this bulleting by clicking the link below: http://www.toyotapart.com/Engine_Bank_1_and_Bank_2A-F_and_O2_Identification_T-SB-0398-09.pdf
  2. Jan 20, 2010 at 3:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Good info.
