Air/Fuel ratio
Discussion in '4 Cylinder' started by vstrom, Jan 18, 2015.
  1. Jan 18, 2015 at 1:07 PM
    vstrom
    vstrom [OP] Well-Known Member
    I just got the Air/fuel ratio programmed into the scangauge.. and I'm curious what it should be reading on the highway? Right now it's steady at 14.5.
    Anyone know what it should be at?
  2. Jan 18, 2015 at 3:00 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Ideal with pure octane would be 14.7:1, but with different additives in the gas it will vary. If it's oxygenated fuel, then the ratio will be lower. Your O2 sensor should automatically adjust air/fuel ratio so there is no excess oxygen or fuel (one way or the other) going to the catalytic converter.
  3. Jan 18, 2015 at 6:48 PM
    vstrom
    Right on, thanks! Guess it's damn near perfect then.
  4. Jan 23, 2015 at 11:44 AM
    Indy
    Indy Master of all I survey.
    You won't see much variation in a NA vehicle unless something is massively wrong.
  5. Jan 23, 2015 at 12:38 PM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    Monitoring your long term fuel trim will help you too. Tells you how much the computer is adjusting the injectors (open time) to keep the air fuel ratio at ideal 14.7:1.
  6. Jan 24, 2015 at 2:28 PM
    vstrom
    Good to know. I'll be programing the fuel trim into the scangauge too, now.
  7. Jan 30, 2015 at 11:58 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    14.5 is good.
  8. Mar 2, 2016 at 6:20 AM
    reloader403
    reloader403 Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    Where can I find the command code for the AFR to have my scan gauge report it ? Thanks
  9. Jun 25, 2023 at 4:23 PM
    Spicy__taco
    Spicy__taco Well-Known Member
    2002 radiant red Tacoma SR5
    Stock
    I see this post is old but I have some air to fuel ratio questions.
    Currently my AFR is fluctuating from 12:1 to 18:1 consistently at idle along with an idle surge.
    I'm wondering if anyone knows what would cause this?
  10. Jul 15, 2023 at 8:51 PM
    ecoterragaia
    Central Virginia
    I would check for a vacuum leak first.
  11. Jul 15, 2023 at 8:55 PM
    Bishop84
    Bishop84 Well-Known Member
    AFR is kinda pointless, it fluctuates.
    Truly what matters is fuel trim long term %, if its +/- 10% thats all that matters.
