Air fuel sensor, upstream passenger side. Bolt torques.
Discussion in '1st Gen. Tacomas (1995-2004)' started by tone1957, Sep 5, 2023.
  1. Sep 5, 2023 at 9:56 AM
    tone1957
    tone1957 [OP] Member
    Tony
    Whittier, CA
    2004 Silver Tacoma 4WD TRD
    Snug Top shell, spray on bed liner.
    I got CEL 0031 and learned that it was the upstream, passenger side. I did a pre-order check to ensure that I could easily remove the flange bolts and electronic connector. It was a success, except that the exhaust stud came out along with the bolt. I am ordering new bolts and 1 stud. I am also ordering the Air Fuel Sensor from rockauto, since it was the correct OEM Denso product (V6, automatic, upstream) at the best price.
    I cleaned the AF Sensor to see if that would clear the CEL. It did for about a minute, so I am pretty sure that the sensor is bad. 2004 Tacoma V6, automatic.
    Does anyone know the tightening torques for the exhaust stud and bolt?
    Thanks.
  2. Sep 5, 2023 at 1:51 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Depends just what studs and nuts you get.
    The higher strength materials will allow a higher torque . Like ARB studs and nuts
    You should be fine at 22 foot pounds.
  3. Sep 18, 2023 at 10:18 PM
    tone1957
    Tony
    Whittier, CA
    I replaced the O2 sensor, cap nuts and the one stud that originally came loose. I cleared the CEL and it has not come back.
  4. Sep 19, 2023 at 9:00 AM
    Bivouac
    Glad you were able to get things repaired!
