Air Injection Pump
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Youright, Apr 26, 2023.
  1. Apr 30, 2023 at 8:23 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I believe the service campaign wasn’t established until 2020, OP should have plenty of time to get it done. I can’t see Toyota opening and closing a service campaign in two years.
  2. May 1, 2023 at 3:40 AM
    AwArD
    AwArD Well-Known Member
    2012 Tacoma Trail Teams TRD sport Double Cab V6 4.0
    Icon Rxt rear leaf option 2 Elka 2.5 DC Reservoir Front/Rear with 600lbs/14inch coil JBA Offroad STD high caster UCA Whiteline LCA inner bushing Mevotech TTX LCA Ball joint Woodward U-Joints Intermidate steering shaft mod Uni filter mod TRD Cat-Back Exhaust Timbren Active Off-Road Bumpstops Front/Rear Overland Torque Tune (OTT) by Yotatune Amsoil signature engine/transmission Amsoil SEVERE GEAR 80W-90 Front/rear diff and T-case Tacoma bed mat Weathertech mat front and rear cabin Summer BFG Ko2 265/65r17 E rated / Fuel Rebel 6 Bronze wheels Winter Nokian Hakkapeliitta 10 studded, 265/65r17 / oem Toyota wheels
    I had till June 2021 for the recall on my 2012 (first time of use 4 June 2012, made early 2012). I think the recall was good for 10 year after first use so for any 2012 left i'm sure que recall is closed unfortunatly....
    If i remember i think the Tundra had similar recall in 2018 and i think some ppl in the US got a letter for the Tacoma mid 2018. I'm sure there some post around here near these date talking about the letter they received in the mail about this recall.
  3. May 1, 2023 at 4:08 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Pdf
  4. May 3, 2023 at 4:54 PM
    Youright
    Youright [OP] Member
    Hawaii
    Update. I’m not sure how long I haven’t noticed since that the check engine light and trac off lights turned off. I smashed the gas to see if I was still in limp mode and I could definitely tell I got my acceleration back. I already ordered the bypass kit and pressure sensor. Not sure if I should just install it anyway in case this is a fluke or get a refund. Anybody had a delayed fix like this before?
  5. May 3, 2023 at 5:37 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    It can come and go. Every time you start it COLD the system runs and the computer is checking the valve and pump functionality. If the valves are gummed up they might pass, but over time it will only get worse.
    You could also buy an ultra gauge and just clear the code. Once the truck is warm the system doesn’t run on subsequent starts and so the computer doesn’t check. As far as I know.
