Air Intake alternative
Discussion in '3rd Gen. Tacomas (2016-2023)' started by austinklindsey, Mar 9, 2017.
  1. Mar 20, 2021 at 8:27 PM
    tedusmc1345
    tedusmc1345 Well-Known Member
    ted
    2018 Tacoma Sport 4x4
    eBay has fake k&n intake for 100bucks.
    I got Trd intake because it’s only intake are carb certified in CA
  2. Mar 21, 2021 at 8:21 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Liked because you called it a "peepshow" and I lold
    Sroberts[QUOTED] likes this.
  3. Mar 21, 2021 at 2:26 PM
    Fpc187
    Fpc187 Well-Known Member
    Righton!! Lol peepshow is very fitting Great reference
  4. Jul 10, 2021 at 5:37 AM
    Hot Taco sauce
    Hot Taco sauce Well-Known Member
    WI
    Dclb lover
    Just starting out, give me time
    So I just installed mine and I am noticing that there is a little motor shake at times of turn on and under gas, so with this pipe being very tight fit are you guys concerned about wear and tear from that being so rigid and not moving like the stock accordion style ring. I might go with a bigger or longer silicone pipe gasket to remedy this. Anybody else see this as a problem??
  5. Jul 10, 2021 at 5:51 AM
    Fpc187
    Ya all engines will move around slightly when starting, revving the throttle or under load unless you are running solid motor mounts. I made sure the aluminum pipe/tube was about 1/4” shorter on both ends for a little wiggle room. when the rubber sleeves are installed you can’t notice. But yes if you wanted you could use something closer to the stock couplers for added movement. Your call
    Hot Taco sauce likes this.
  6. Jul 12, 2021 at 10:42 AM
    Sroberts
    Sroberts Well-Known Member
    Sean
    Vancouver, Canada
    2017 Tacoma TRD O/R Blazing Blue DCSB
    After about 6 weeks of waiting for the parts for my custom intake with zero communication from the supplier, I asked for an update (Motorwise.ca) and they basically just gave up and refunded me..idiots.
    Ended up grabbing a K&N intake tube.. No Ragrets. Sounds mean at WOT.
    Junkhead likes this.
  7. Jul 12, 2021 at 10:45 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    And that's all this mod does.
    Chew and CoastieRon[QUOTED] like this.
  8. Jul 12, 2021 at 10:52 AM
    Sroberts
    Sean
    Vancouver, Canada
    We know, bud. :D
    CoastieRon likes this.
  9. Jul 12, 2021 at 11:15 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I dealt with motorwise twice. Once I tried getting an intake tube, it said it would fit but it took them like 3 months to reply and refund me money saying it won’t fit. The second time was great experience, I got the Borla exhaust for awesome 790 and it came in about 2 weeks.
    Regarding an intake, I got a trd filter, hps silicone tube, charcoal filter delete and air flow accelerator. Sounds great!
    AmateurTaco1313 likes this.
  10. Jul 12, 2021 at 4:16 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I've got the TRD intake. Does the charcoal filter delete make it sound any better just by doing that?
    Junkhead[QUOTED] likes this.
  11. Jul 12, 2021 at 6:47 PM
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    Yep. I have no illusions otherwise. I wanted a piece of cheese h der the hood, and I got what I wanted
  12. Jul 12, 2021 at 6:54 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I'm curious.........
    How much time do you spend driving at WOT??
  13. Jul 12, 2021 at 8:41 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    At least once or twice when I get behind the wheel. Well worth it:).
  14. Jul 13, 2021 at 12:22 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I think a little bit, might be all in my head though. Dropping in the trd filter made it a bit louder for sure.
  15. Jul 13, 2021 at 7:21 PM
    #35
    tedusmc1345
    ted
    I have Trd intake exhaust, the throttle response make like it’s a complete different truck. Before intake and exhaust I have a alternative peddle commander.
  16. Oct 31, 2023 at 3:25 AM
    #36
    hmgtaco09
    hmgtaco09 hmgtaco19
    2019 Tacoma TRD off-road dlbcab
    Bilstein 5100, OME 887 Coils second notch, SPC UCA, Deaver 1.5-2 AAL
    How's this set up holding up for you guys who did it? Still liking it?
