Air Intake "Gasket" Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bkrdave36, Jan 29, 2020.
  1. Jan 29, 2020 at 7:11 PM
    bkrdave36
    bkrdave36 [OP] Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    Does anyone know if there is a replacement (or DOY fix) for the foam "gasket" on the air intake tube that goes through the passenger side wall just behind the window washer reservoir? Mines shot and it vibrates a lot when the engine starts up. Very annoying.
  2. Jan 29, 2020 at 8:42 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    I took the bolts out that secures the intake down and wedged cardboard under the intake so that when I rebolted it down it had no play at all and it's been quiet ever since
  3. Jan 30, 2020 at 2:46 AM
    benzy
    benzy Well-Known Member
    Bay Area, CA
    2006 DCSB TRD OR
    Simple OME/884/AAL lift. 32” WP’s
    I think I used 1/2” wide weather stripping.
    Alexely999 likes this.
  4. Jan 30, 2020 at 7:21 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Home depot will have weather stripping with sticky on one side should work like a charm for ya.
  5. Jan 30, 2020 at 1:08 PM
    bkrdave36
    Dave
    Wittmann,AZ
    So no replacement gasket. Got it.
    I will find some thick weatherstripping then.
    Thanks for the input everyone.
  6. Jan 30, 2020 at 2:50 PM
    tathambenjamin
    tathambenjamin Well-Known Member
    ben
    2008 4Runner SR5
    -2.5/1.5 spacer lift -270/65/17 Cooper AT3
    I just wrapped the end going into the fender in electrical tape and then put some new adhesive on the old foam gasket- free and no more rattling.
  7. Jan 30, 2020 at 5:24 PM
    bkrdave36
    Dave
    Wittmann,AZ
    Unfortunately my foam is all jacked up and not reusable. I guess I replaced the air filter and spark plugs too many times and messed it up!
