Air intake
Discussion in '4 Cylinder' started by Trace0, Dec 6, 2014.
  1. Dec 6, 2014 at 12:26 PM
    Trace0
    Trace0 [OP] Member
    96 2.4 tacoma
    i just put a new air intake on my 96 2.4 l automatic tacoma and now i cant do over 35 mph and i have no idea what it could be
  2. Dec 6, 2014 at 1:40 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Check for open vacuum lines, or your Mass Air Flow sensor. ;)
    Greg
  3. Dec 6, 2014 at 1:41 PM
    Trace0
    Trace0 [OP] Member
    96 2.4 tacoma
    Not sure what that is I'm new to all this but none of the sensors will connect to my new air intake
  4. Dec 6, 2014 at 1:43 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Sounds like you got the wrong intake. You need all those sensors
  5. Dec 6, 2014 at 1:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Dude, put it back to stock..
  6. Dec 6, 2014 at 1:54 PM
    Traviste
    Traviste Now with more woopow
    Travis
    Georgia
    2014 DCSB Locked 4x4 Mid-Travel
    F:King 2.5 coilover resi ext 700#coils R:King 2.5 ext allpro expos
    Sounds like wrong intake
  7. Dec 6, 2014 at 2:10 PM
    Trace0
    Trace0 [OP] Member
    96 2.4 tacoma
    I know this is compleat different car but my friend put on on his 98 Honda civic and never put the sensors back on and it worked haha but I'm pretty positive I had the right one everything it said was for my truck idk I'll look for another and send this one back
  8. Dec 6, 2014 at 9:09 PM
    tooter
    Greg
    Los Angeles
    Put your stock intake back on, and make sure you reconnect everything just like it was. It's as good a cold air intake as you'll ever find.
    I had a '96 2.4 for 17 years, so I know. ;)
    Greg
  9. Dec 6, 2014 at 9:21 PM
    Trace0
    Trace0 [OP] Member
    96 2.4 tacoma
    Well I have to since I can't do over 35 with my new air intake gotta go back to the old haha but alright thanks!
