Air intake
Discussion in '3rd Gen. Tacomas (2016-2023)' started by quicksand_taco207, Mar 12, 2021.
  1. Mar 12, 2021 at 5:41 PM
    quicksand_taco207
    quicksand_taco207 [OP] Active Member
    2020 toyota tacoma sr5
    3inch lift on 33s Black overlays including tailgate overlays ditch lights lightbar OEM bed mat seat covers
    What’s the Best air intake for these trucks?
  2. Mar 12, 2021 at 5:41 PM
    Tacospike
    Two Trucks
    3,2,1
    T8tjt, CJH9980, Hooper89 and 7 others like this.
  3. Mar 12, 2021 at 5:42 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    In before the “your rig comes stock with the best one” comments
    CJH9980, Hooper89, JasonLee and 6 others like this.
  4. Mar 12, 2021 at 5:49 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
  5. Mar 12, 2021 at 5:56 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    In fairness, the stock ones are very good.
  6. Mar 12, 2021 at 6:57 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Define best?
    Performance wise=stock,
    sound wise without loosing performance=TRD.
    Most others, probably like TRD but less $$.
    What some /many people call CAI, (cone filter in engine bay) = simply shit.
    basically on stock engine there are no performance gains to be had from airbox changes.
    Chew likes this.
  7. Mar 12, 2021 at 7:15 PM
    waltuo
    Toyotas
    CAI is not necessarily cone shaped.
  8. Mar 12, 2021 at 7:18 PM
    Bishop84
    Bishop84 Well-Known Member
  9. Mar 12, 2021 at 7:20 PM
    Tigris99
    Tigris99 Well-Known Member
    St Louis
    2021 AG Trail edition
    Stock, cold air intakes and K&N style filters are total garbage. Do nothing, help nothing, but do a good job of letting a ton of crap into your intake that should have been filtered out.
  10. Mar 12, 2021 at 7:35 PM
    mutely
    True CAI is definitely not coned shape. (Unless completely shielded in a box). Read what I wrote again.
  11. Mar 13, 2021 at 11:22 AM
    waltuo
    Toyotas
    I don’t have to. Your definition of a CAI is right there in bold.
    have a good day buddy.
  12. Mar 13, 2021 at 11:43 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    :anonymous:
    Just cause these threads are always a complete shit show, technically just about any intake, regardless of boxed or not is a cold air intake under driving conditions.
    Air flow enters both through ports intended for the intake as well as through the grill and underneath the vehicle. This air will be colder than the air at the manifold. Both due to movement of the air and the fact that the ambient air will be colder than the ambient temp of the engine and intake manifold.
    Non heat shielded intakes will be more subject to heat soak, but once youre moving its moot point.
    The stock intake tubing though, utilizes resonators to keep it quiet, which can affect laminar airflow and increase cavity size. Vacuum will be reached at a different rate, air will move at a different velocity. You can argue the pros and cons of this, but it is most likely why people always mention better throttle response, and likely plays a large part in seeing some sort of power increase.
    Fun thing is, people that have aftermarket intakes and have had their vehicle dyno'd with said intakes can show results to people who dont have aftermarket intakes and dont have dyno results. Despite being able to show actual measurable increases in power, even if marginal, the latter will insist they "dont increase power". :confused:
    Disclaimer, while I have dyno'd multiple vehicles in the past and seen power increases from aftermarket intakes (on every one), I haven't done so with a Tacoma. Nonetheless, anyone stating they do nothing without a dyno is as accurate as anyone stating they make power, with out a dyno.
    Scott4032, Taco1004, Junkhead and 3 others like this.
  13. Mar 13, 2021 at 11:53 AM
    waltuo
    Toyotas
    This should be the first and last post on any future intake threads.
    Taco1004 and VaToy like this.
  14. Mar 13, 2021 at 1:53 PM
    mutely
    that’s NOT my definition, that’s the definition of many people that have it wrong. If you read the actual words written again there is absolutely no way you could come to the conclusion that it’s my definition.
    black_angus1 likes this.
  15. Mar 13, 2021 at 2:14 PM
    waltuo
    Toyotas
    You included that part, not everyone else. When people say CAI, I never see them referring to just the “cone” type.
    Look at the other hundred threads, no one has specifically said cones are the only CAI types. But, you referred to cones specifically.
    Like I said, have a good day little buddy. I know I am.
  16. Mar 13, 2021 at 2:19 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    HPS tube, air flow accelerator and trd filter. FTW.
  17. Mar 13, 2021 at 2:24 PM
    elduder
    Van WA
    Cheaper, probably just as effective. OE filtering. :thumbsup:
  18. Mar 13, 2021 at 4:18 PM
    Jerry1026
    Jerry1026 Well-Known Member
    Jerry
    PNW
    2019 TRD OR DCSB
    I agree!
    Junkhead likes this.
  19. Mar 13, 2021 at 7:55 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Yep! Maybe even better, trd intake comes with the resonator box, which defeats the whole purpose IMO.
  20. Mar 13, 2021 at 8:04 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    just get a dry drop in filter. dont get held up by "cold air intake" gimmicks .they serve no purpose .
    Capespencer68 and Chew like this.
