Air is always a little warm (When outside air is cold, A/C off, and dials set to cold)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Presto6, Apr 23, 2025.
  1. Apr 23, 2025 at 1:17 PM
    Presto6
    Presto6 [OP] Member
    2015 Tacoma TRD Off-Road
    None
    In the mornings when the air outside is cool, I just want the truck to blow that cold outside air inside the truck, however even on the coldest setting (without turning the AC on, as its plenty cold outside) the air coming out the vents is still siginificantly warmer than the outside air. I assume this means the air is still passing through the heater core, and that even when the A/C is on, its passing through the heater core first. Is there anyone to change this, or is some blend door broken? I live in phoenix, and would rather never have any hot air.
    HondaGM likes this.
  2. Apr 23, 2025 at 1:21 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Check the operation of the Air/mix Motor?
  3. Apr 23, 2025 at 1:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    No, there is no way to really fix it.
    The air coming in from the blend air door (recirculate door) pulls hot engine air in from the engine bay. Sure, you can close off the door. but then you're just blowing the same cabin air around. What's the point?
    Roll down the windows if you want that cool air. That's what I do.
  4. Apr 23, 2025 at 3:48 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    It's all speculation without actual ambient, vent temp.'s
