Air Locker RD232 on a 2019 MT Sport
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pablo8, Sep 23, 2019.
  1. Sep 23, 2019 at 7:37 PM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Considering a larger $ acquisition.
    8.75" 5.29 Nitro Gears, and ARB Rear Air Locker
    Around $2500 in parts including compressor.
    Should I do it? :D:spending:
    What about a front air locker?
    I think I will like the 5.29 because 2 OD 5 and 6, and wanting lower 1-2-3 and R.
    If I do it, it will be a large project and will do ADM and R only Low switch at the same time.
    Discuss, throw rocks, etc What am I neglecting?
    Junkhead likes this.
  2. Sep 23, 2019 at 7:43 PM
    Bishop84
    Bishop84 Well-Known Member
    Front lockers on Toyotas means breaking tons of CV axles, It's best to start with the rear and see how you fair.
    I would only put a lock the front if I was having trouble keeping up with the group I was going with.
    AdventureKid and Pablo8[OP] like this.
  3. Sep 23, 2019 at 7:45 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    I’ve been locked front for over a year now. No broken CVs. Go locked in both diffs if you’re regearing anyways.
    whatstcp, SR-71A and Pablo8[OP] like this.
  4. Sep 23, 2019 at 7:47 PM
    Bishop84
    My personal experience, with a few of my customers/co-workers. It might have to do with terrain, size of the tires, and driver.
    You are right though, the diff is torn apart and you're commiting.
    Pablo8[OP] likes this.
  5. Sep 23, 2019 at 8:05 PM
    BSCowboy
    BSCowboy Well-Known Member
    RENTON, WA
    19 Taco-TRD.OR.DC.LB
    Dirt & dogs LEER 100XR Topper NOICO Sound Deadener & Insulation OEM Audio Plus Decked Marathon Seat Covers Pop & Lock WeBoost Drive Reach {removed} Anytime Camera install Falcon Suspension System Nitro 5.29s {soon} Method 702 (not sure on tires)
    Don't you have an e-locker on the 2019 OR 4x4 MT? Just curious, cause I have a 2019 OR 4x4 AT.
  6. Sep 23, 2019 at 8:10 PM
    doannutglaze
    doannutglaze Well-Known Member
    2016 MGM Tacoma TRD Sport
    He has a sport
    whatstcp and BSCowboy like this.
  7. Sep 23, 2019 at 8:11 PM
    BSCowboy
    RENTON, WA
    Doh!
    GillyLink likes this.
  8. Sep 24, 2019 at 3:28 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    I knew I wasn't getting a stock e-locker when I went into this......but I also thought 4.88 would be fine :D
  9. Sep 24, 2019 at 5:07 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    if you got the pockets go eaton e locker, idk if it's stronger, but it's easier.
    I'm running 285/75r16 and of course you don't bounce, you learn how to drive with the front locker engaged. It makes it where momentum isn't needed for most stuff.
    carry a spare CV with you just in case of course, but honestly you shouldn't have an issue unless you start bouncing wheels off ground.
    Pablo8[QUOTED][OP] likes this.
  10. Sep 24, 2019 at 5:15 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Thanks#
    How much is it? Eaton.
    Easier? You mean installation?
  11. Sep 24, 2019 at 5:18 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    So I've never seen or heard an air locker. What is the process? Flip the switch, compressor comes on and actuates ? Delay time?
  12. Sep 24, 2019 at 5:26 AM
    whitedlite
    USA!
    3RD Gen TRD 4WD
    installation is going to be similar, eaton may not be as strong, but it's never going to have an air leak.
    when offroading the compressor stays on, lockers are flip of a switch and basically instant. You can activate them while approaching an obstacle. They actually activate better this way because it helps the splines lock in where they should be. When engaging sitting still the locker may not full engage till you creep forward or reverse a tiny amount. It's basically instant though.
    when you're ready to disengage don't stop, just flip switches off for lockers, keep compressor on if still offroad if you want, and it does it's thing.
  13. Sep 24, 2019 at 5:29 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Great info! I assumed separate switch for compressor. Thanks!!
    whitedlite[QUOTED] likes this.
  14. Sep 24, 2019 at 5:40 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    If you have an air tank keep it pressurized all the time, then you just need the locker switch which is instant.
  15. Sep 24, 2019 at 6:30 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Maybe not many Gen 3 folks running ARB Air Lockers. I wonder if Gen 2 guys tried them? Tried searching and all I did was watch jeep videos of breaking POP :popcorn::taco:front axles :beavisd::ohsnap:
  16. Sep 24, 2019 at 10:40 AM
    deuce189
    deuce189 Well-Known Member
    Kev
    Charleston, SC
    2019 Cement SR5 Prerunner *SOLD*
    Hunting for a 4g
    Sub'd... i'm researching adding a locker on my sr5 2wd... i'm trying to get an answer from a Harrop Distributor to see if they have a Elocker that fits the my 3rd gen SR5.
  17. Sep 24, 2019 at 10:46 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    This makes me question why you didn't buy an OR in the first place if you thought you'd be doing a locker. Having the locker & Crawl Control for almost the same price as a Sport is a no-brainer.
  18. Sep 24, 2019 at 10:57 AM
    Pablo8
    Pablo8 [OP] Here!
    Paul
    Everson WA
    Long bed, MT, AC in OR. GO.
  19. Sep 24, 2019 at 11:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :cheers:
    Until the US gets an ACLB MT OR like our Canadian friends, the Sport versus OR arguement is BS.
    :poking:
    If we're talking DCs or ATs, then the OR makes all the sense in the world.
    Junkhead and Pablo8[QUOTED][OP] like this.
  20. Sep 24, 2019 at 11:05 AM
    eon_blue
    Azusa, CA
    A rear locked 4x4 is a night/day difference in capability over open diff 4x4....start with a rear locker and worry about doing the front if you think you still need it.
    Front lockers are for people that go beyond the 'most difficult' rated trails and into the extreme rated territory. Most people don't really need a front locker. And like mentioned earlier, front CV axles are far weaker than the axle shafts in the rear and are easily broken if you aren't careful driving with the front locker engaged.
    Unless you're re-gearing front/rear, then it may make sense to go ahead and put a locker in both since you have it torn apart anyway.
