Air matress that will fit 6 foot bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badhaircut, Sep 2, 2018.
  1. Sep 2, 2018 at 7:47 AM
    badhaircut
    badhaircut [OP] Well-Known Member
    2012 TRD double cab long bed
    I checked out that long camper thread and its full of useful set ups. I have been shopping for an air mattress but they all seem to be between 73"-75" long.
    I picked up this air mattress at Walmart https://www.walmart.ca/en/ip/intex-twin-comfort-plush-airbed-with-built-in-pump-13/6000148921143 and it's perfect because it has a built in pump which can work on the 110 outlet at the rear of the truck.
    The problem is that the mattress is approx 75" long. My bed with the gate closed is 72" and I am concerned that closing the gate will put too much pressure on the air mattress.
    if I open it and inflate it, I can't return it so I'm looking for anyone who has had a similar experience.
    Then I came across this which is made to fit a Tacoma and it's 76" https://www.amazon.ca/AirBedz-PPI-1..._1_52?s=sports&ie=UTF8&qid=1535900070&sr=1-52
    Any thoughts?
  2. Sep 2, 2018 at 8:07 AM
    Pigpen
    Dan
    Northwest Montana
  3. Sep 2, 2018 at 8:11 AM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    I have a twin size air mattress. Fits perfectly with tailgate up. Not sure of the brand, bought it years ago.
  4. Sep 2, 2018 at 8:12 AM
    turkeyeye
    turkeyeye Well-Known Member
    Henry
    Western NC
    There are several 72" air mattresses on Amazon: search 72 air mattress.
  5. Sep 2, 2018 at 8:24 AM
    badhaircut
    Hi do you have a brand and model? Any idea what the mattress length is when inflated?
    Thanks a lot!
  6. Sep 2, 2018 at 9:17 AM
    Muddinfun
    Muddinfun Well-Known Member
  7. Sep 2, 2018 at 11:02 AM
    badhaircut
    Muddinfun[QUOTED] likes this.
  8. Sep 2, 2018 at 12:21 PM
    vtdog
    vtdog Well-Known Member
    NH
    Norm Abrams has often said "measure twice, cut once". I looked at the info on the Walmart website, it says "Dimensions: 39" x 75" x 13". So, lets see: 72" bed, 75 in mattress. You do the math!
  9. Sep 2, 2018 at 12:54 PM
    badhaircut
    So what you are saying is that 75" - 72" is 3" correct? You are really good at the maths. I thank you for this constructive and non trolling post. You are a true contributor to this forum and others I'm sure.
    PS: Remind me to never to go any parties you attend.
  10. Sep 2, 2018 at 6:36 PM
    Tango Bravo
    Thomas
    SoCal
    I think its a Coleman. 72" long. I bought it a few years ago before Sport Chalet closed in the states. It has been surprisingly durable. I've taken it on a bunch of truck and motorcycle camping trips.
