Air mattress for 2013 double cab tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chobo, Apr 20, 2015.
  1. Apr 20, 2015 at 8:48 AM
    Chobo
    Chobo [OP] New Member
    Hey guys, new to the forums and new owner to a 2013 Tacoma. I've recently been trying to figure out a way to make my truck bed comfortable enough to sleep on. It couldn't be that hard, right? After some research and ordering a truck mattress that didn't fit my bed, I'm stuck.
    I ordered the Air Bedz 6' mattress to try to fit it into my 5' truck bed. As you could guess, no luck. The length and width was perfect with my tailgate down, but the wheel wells were off.(Picture added)
    Does anyone know of an easy solution to this problem? I've tried looking for Truck Bedz expedition (tailgate down model), but they don't seem to be in stock anywhere. If all else failed, I might just have to pile blankets and pillows until I can order an air mattress that fits.
  2. Apr 20, 2015 at 8:59 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
  3. Apr 20, 2015 at 9:13 AM
    Chobo
  4. Apr 20, 2015 at 9:37 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I have never had good luck with an air mattress unless it's a thermarest. Those big pillowy bastards are super-uncomfortable and wiggly, then they spring mystery leaks even if handled like a premature baby. Never again.
    What I like the best is a bedliner made from styrofoam sheet insulation so you don't feel the ridges of the truck bed, and it also blocks some cold coming from underneath. If you wanted to be a fancy lad you could even cover it with some cheap automotive carpet. Then with a thermarest or foam pad on top of that, you will sleep like a king.
  5. Apr 20, 2015 at 9:51 AM
    Geoff
    Geoff Well-Known Member
    Adirondack Mountains
    2023 TRD OR
  6. Apr 20, 2015 at 9:55 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    I was super confused looking for one to fit our bed as well, no clear cut specific model for Tacoma really from what I could find. Ended up just getting a normal queensize one from Amazon for pretty cheap, super comfortable...
  7. Apr 20, 2015 at 10:33 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    My air mattress is about a 12 pack. After that, everything is comfortable to sleep on.
  8. Apr 20, 2015 at 10:41 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    I had one of those Intek mattresses from walmart last for well over a year. Since I travel a lot for work, a lot of time I am a cheap o and sleep in my office at different locations. It was great. I was sad when it finally broke, it didn't develop a leak, but one of the baffles came loose from the bottom and it had a huge bulge in it.
  9. Apr 20, 2015 at 11:30 AM
    nd4spdbh
    SoCal
    you just have to go costco and they have it there.
    The little personal self inflating sleep pad is super comfy and its great, no need to bring an air pump, its not crazy thick so i can use it in my small tent that fits in the back of my truck.
    It will not fit two people though.
    As far as actual air bed that fits the truck
    http://www.truck-bedz.com/5-cargo-box/
    But really you could probably do alot cheaper if you got a tape measure out and measured inbetween the wheel wells and then length of the bed with the tailgate down and go to walmart and get an air mattress there.
