Air On Board Switches Under HVAC Panel?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by steveo27, Jan 23, 2017.
  1. Jan 23, 2017 at 10:03 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Air On Board sells switches sold as "Toyota Tacoma 2012-ON Center ONLY" switches - http://www.aironboard.com/online/pu...ta-oem-replacement-rear-locker-green-red.html
    I assume this means they fit under the HVAC panel, correct?
    Can anyone verify if these will fit older model trucks that have the 3 switch blanks under the HVAC panel? I know you can swap the 3 blank panels for the newer style 4 blank panels.
    I am looking for an OEM style switch to fit this panel.
    ChadsPride likes this.
  2. Jan 24, 2017 at 3:47 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I bought the Mictuning. They are half the price and fit perfect but I have a 4 switch panel. Just measure the face of one of the OEMs and compare to specs on the new one or pull one and measure opening.
  3. Jan 24, 2017 at 6:51 AM
    steveo27
    Pittsburgh
  4. Jan 24, 2017 at 11:25 AM
    stump jumper
    Bill
    Texas
    Probably the same switch but mine were for Tacoma an came in multiple colors and graphics. Don't have a pic of switches right now. Bought from Amazon to combie with other stuff for free shipping.
  5. Jan 24, 2017 at 11:48 AM
    dirtdigginjoe
    dirtdigginjoe Resident meth-head
    Joe
    Long Island, NY
    Paco The Turbo Taco
    GTX 3071r @8psi...
  6. Jan 24, 2017 at 11:49 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I think they changed sizes at some point tho, and 2012+ switches in the center aren't the same as 05-11 center switches
  7. Jan 24, 2017 at 5:25 PM
    steveo27
    Pittsburgh
    Both Mictuning and CH4x4 show the under HVAC switches being 22mmx32.5mm, which matches the under HVAC switch blanks in my 2011
  8. Jan 24, 2017 at 11:55 PM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I just bought the exact air on board one you mentioned.. fits below the hvac perfectly.
  9. Jan 25, 2017 at 3:36 AM
    stump jumper
    Bill
    Texas
    The Mictuning do not include a wiring diagram but do not start bitchin like I did. When I settled down I found it on the net.
    JKU3000 likes this.
  10. Feb 2, 2017 at 11:33 AM
    ZFlyingTaco
    ZFlyingTaco Active Member
    CA
    '15 TURD Sport 4x4
    Pelfreybilt sliders BFG tires ProComp wheels Diff breather Lights
    Good info
    JKU3000 likes this.
