Air only comes out of the vents on full blast (2005)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pyrotechnika, Mar 23, 2022.
  1. Mar 23, 2022 at 10:08 AM
    Pyrotechnika
    Pyrotechnika [OP] Member
    Eric
    2005 Blue Tacoma V6 4.0L
    Kept it alive
    Like the title says, I can only get air when I have the air force on full blast. It's not weak either, its pretty intense. Id like to enjoy more settings that aren't just off and hurricane force.
  2. Mar 23, 2022 at 10:10 AM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    Welcome to the club. You need a new fan switch, pretty common issue on these trucks.
    Pyrotechnika[OP] likes this.
  3. Mar 23, 2022 at 10:11 AM
    Pyrotechnika
    Eric
    Kept it alive
    Thanks dude, I'll check them out
  4. Mar 23, 2022 at 10:14 AM
    10YSON
    GREG
    TACOMA & 4RUNNER
    I got mine on flea bay. I tried to find you a link to the one I purchased but it's been so long it's no longer in my purchase history.
  5. Mar 23, 2022 at 10:15 AM
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Sorry, I interpreted your title wrong. I thought you were expecting something else besides air to come out of your vents.
  6. Mar 23, 2022 at 10:19 AM
    Pyrotechnika
    Eric
    Kept it alive
    Yeah looks like an easy fix. Looks like it'll just cost me around 20 smackers and 5 mins of my day.
  7. Mar 23, 2022 at 10:20 AM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Before you buy anything, wiggle the resistor under the glove box. Mine did the same thing and periodically I would have to wiggle/have a passenger kick it and it would be fixed. Haven’t had to wiggle it in about 40K miles.
  8. Mar 23, 2022 at 10:23 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Resistor is more common to go bad than the switch, plenty of threads on here detailing both.
    Jimmyh, Fullboogie, TnShooter and 2 others like this.
  9. Mar 23, 2022 at 10:23 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    Sound like a bad blower resistor to me. When the switch is on full blast the resistor is bypassed and the blower runs at full tilt. Anything lower than that it runs through the resistor and if there's a break in it blower no worky.
  10. Mar 23, 2022 at 10:24 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    its the blower resistor. Not the fan switch.
    I had the exact same thing happen a few years ago. Only worked on high. New resistor and it works good as new.
    pretty common issue on 2nd gens. There’s tons of threads about it on here.
    Fullboogie and Dm93[QUOTED] like this.
  11. Mar 23, 2022 at 10:25 AM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    It's probably not the fan switch itself, but the blower motor capacitor which has burnt out and needs replacement. I've had this same issue on many trucks.
    It is likely that you will need to cut wires and patch together a new connection for the wire harness. You can tell if you need to do this because the connectors will smell and look burnt. Do not skip this step if your contacts on the connectors are burnt, as you will just burn out the new capacitor (ask me how I know...).
    The OG OEM resistors on this truck were made in Slovakia and their quality is a testament to how damn long they last. The new OE/OEM replacements are all made in Mexico, look different than the original, but work very well.
    https://www.youtube.com/watch?v=R7QaPNgZCTA
    Get your parts, grab a beer, watch this video, and get goin.
  12. Mar 23, 2022 at 10:57 AM
    Pyrotechnika
    Eric
    Kept it alive
    I pulled out the resistor and its burnt up. Im just gonna try replacing that since I think the switch is probably fine. The wiring harness has some crisp in a female connector so ill cut it off and replace that too since it comes with the resistor. Thanks guys I really appreciate the help. This forum is pretty dope
    ToyodaSun likes this.
  13. Mar 23, 2022 at 11:22 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It won’t hurt to pull the plug on the blower and inspect it too. While not as common as the resistor, it’s been known to melt/burn too. You are already down there, it won’t hurt to have a look.
    I mean the switch, the resistor, and the fan have all been known to burn the plugs. 90% of the time it is only the resistor plug.
    Jimmyh and Fullboogie like this.
