Air Pistol
Discussion in 'Off-Topic Discussion' started by gavonder, Sep 17, 2008.
  1. Sep 17, 2008 at 3:21 PM
    gavonder
    gavonder [OP] She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    I'd like to buy an air pistol - either .177 pellet or BB. I have to admit, the main reason is to keep squirrels, and woodpeckers off of the house.
    I was wondering if anyone has any information or opinions on what would be a nice accurate pistol under $130.00.
    I found this site http://www.airgunwarehouseinc.com/
    but there are too many to choose from.
    Any help??
    GA
  2. Sep 17, 2008 at 3:33 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
  3. Sep 17, 2008 at 3:35 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    My husband and I shoot airsoft and we have our own arsinal of guns. My husbands airsoft pistol doesn't shoot very high in FPS (feet per second) because it can't (regulations for our playing field). I'm not sure what's available that'll go faster than 200+ FPS. We've shot rabbits in the backyard with it and it doesn't do much in terms of 'ouch' factor.
    However.... We have an old steal bb pump action bb gun at the house that I've used also. As much as I hate to admit it, killed a rabbit with it (accidentally of course). Too many pumps on that gun renders a very fast and powerful bb.
    For the amount of time you're gonna use it.... I'd look for a pump action that doesn't require any batteries or gas to operate it. Just pump it up and shoot. It'll always be ready for you to use. Steal or pellets, doesn't matter.
  4. Sep 17, 2008 at 4:34 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
  5. Sep 17, 2008 at 4:35 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    u can get a pellet rifle from wally world or the likes for pretty cheap. as long as u use a field pellet instead of a BB, it should be fairly accurate. u can even get a cheap scope for the rifle as well
  6. Sep 17, 2008 at 4:38 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Seriously though, I do have that air rifle I linked in my previous post. I would hate to get hit by a pellet from it.
  7. Sep 17, 2008 at 4:39 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    Is there a Gander Mountain retail store near you?
  8. Sep 17, 2008 at 4:42 PM
    ERdept
    ERdept Well-Known Member
    You need at least 8-12 ft lbs of energy to kill these thing. Although I can be done, I don't reccommend it with a pistol due to innaccuray and low energy.
    I'd get a spring piston rifle in .22. It has more weight in grains. The .177 is way to light. do not shoot BB's. they are steel and do not expand and are not accurate as soft lead pellets going down some rifling. Plus on impact, they expand and dump their energy, killing more quickly.
    For clean humane kills please use a spring piston rifle in .22 cal. Look at Beeman in google. This is a break barrel gun, that loads at the breech, when you cock the barrel by "breaking" it from a ball detent. Then when you pull it back, you compress a large single spring that when fired, released its energy which then pushes a "top hat". This is a thing that pushes air from the decompressed spring, out of the spring chamber to the port that leads to the breech.
    This then propels the pellet. They are very powerful, usually, 600- 1000fps. And with a .22 placed in the vitals or head is sure to kill.
    OR..
    Check out Airgun forums as well, known as the "yellow forums" Lots of links at the top. Straightshooters, Pomona Airguns, Airguns of Arizona, Compasseco, etc. All good to deal with. Spend a little more, aroung the $200-300 range and you'll be happy.
    http://www.airgunforum.org/
  9. Sep 17, 2008 at 5:03 PM
    gavonder
    Ct
    Thanks for all of the replies.
    I don't think I want a rifle - a little too cumbersome and obvious in my neighborhood.
    I'm not so sure I want to kill them as much as scare the *@#t out of them, so it doesn't need to be high powered. I just want something quality made, will last and is accurate.
    Thanks,
    GA
  10. Sep 17, 2008 at 8:42 PM
    ERdept
    OK, if pistol it is you may try the Beeman P1 magnum. Power of a rifle in the size of a pistol and avail in .20 cal (heavier pellets).
  11. Sep 17, 2008 at 8:46 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Want a rocket? JK
  12. Sep 18, 2008 at 2:02 PM
    joedirt
    joedirt Hallow
    Ploeśti
    2005 Tacoma
    If you don't want to take them out, get an airsoft gun like Janster was talking about. They shoot a 6mm plastic bb that hurts like a bitch when you get hit but does no permanent damage.
