Air Pressure - 265 70 17 Falkens?
Discussion in 'Wheels & Tires' started by tundraconvert, Jun 30, 2018.
  1. Jun 30, 2018 at 8:43 PM
    tundraconvert
    tundraconvert [OP] Well-Known Member
    Eric
    San Diego
    2017 White Tacoma DCLB TRD OR
    What are you guys running for air pressure on 265 70 17 Falken Wildpeaks?
    I’m trying to get an approximate to start with for maximizing mpg’s.
    Thanks.
  2. Jun 30, 2018 at 8:55 PM
    Bishop84
    Bishop84 Well-Known Member
    You have a topper so a little more in the rear but nothing serious, you have a rigid tire that requires lower pressures to create even wear.
    I would suggest 32 front 34 rear personally. Anything higher and you'll see serious center tire wear and create feathering. Also it will ride much nicer under 35psi.
    I used to run 30psi on my Duratracs
    tundraconvert[OP] likes this.
  3. Jul 1, 2018 at 5:15 PM
    tundraconvert
    Eric
    San Diego
    Thanks.
