air pressure/ gas milage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco2go, Sep 9, 2012.
  1. Sep 9, 2012 at 3:00 PM
    taco2go
    taco2go [OP] New Member
    California
    tacoma 6cy,6speed
    2008 tacoma 6 cyl. 6 speed. 265 - 75R 16 BFGoodrich all terr. tires.What pressure should I have in tires for best gas milage?
  2. Sep 9, 2012 at 3:22 PM
    conquistador
    conquistador Well-Known Member
    Tulsa, OK
    88 4Runner
    best mileage 50+ psi. But I would recommend 35 psi
  3. Sep 9, 2012 at 3:23 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Do not put anything in your tires over the recommended air pressure labeled on the side of the tire!!!!
    Check the side of your tire and bring it to the max PSI.
  4. Sep 9, 2012 at 3:23 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Yup if you run high you will get better mpg. But tread life will go way down. If you do you will notice tread in the center will wear down fast.
  5. Sep 9, 2012 at 3:45 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    No...do not bring it to the max psi!
    My BFG A/T'S in that size are e rated. The pressure labeled on the side is for the max pressure (either 80 or 90 psi.) You'll never want or need to go even close to that psi. For a unloaded bed to light load go with around 34-36 psi. The chalk test will confirm this.
  6. Sep 9, 2012 at 3:46 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Chalk test.
  7. Sep 9, 2012 at 3:47 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    I was more concerned about the lower rated tires for safety reasons. ^ is a valid point as well.
  8. Sep 9, 2012 at 3:50 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    38.5.... good middle ground ive found.
  9. Sep 9, 2012 at 5:03 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you pay attention, you will also notice a huge decrease in traction, as well as poor handling. If you loose control of your vehicle because of overinflated tires, you will wish you left the tire pressure closer to the recommended range (or chalk tested), and did whippersnapper's tach/speedo mod for fuel economy instead.
  10. Sep 9, 2012 at 5:18 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The sidewall max is not the max pressure for the tire.
    It's not even close. The max pressure is simply an indication that "At XX psi, the tire will carry YYYY pounds"
    That's all it is. At pressures lower than "XX", the carrying capacity drops. At pressures above "XX", the capacity does not increase.
    The sidewall rating is not the max pressure, it is the max load.
    You may or may not see the tread wear increase.
    I have always run my tires at high pressures. My Ford Escort used to get 60k out of a set of Sears cheapies that were rated 40k. I ran the sidewall max, and even at that, the tires wore on the edges before the center.
    I ran BFG KO's on my Silverado. Bed was not loaded heavy. Ran them at 70psi. At 35k, tread depth was dead even across the tire on all 4 tires.
    Handling is improved due to the reduction in sidewall flex and tread squirm.
    Tire life is improved due to cooler running temperatures because of the reduction in sidewall flex and tread squirm.
    Navy tests at Pax River showed that the speed at which a tire will hydroplane is directly proportional to it's inflation pressure. I don't recall the exact formula, but a 28psi tire will hydroplane at 55mph. At 35psi that moves closer to 70.
    Dry traction in dirt, gravel, and under other marginal conditions does suffer, but dry traction on clean pavement is improved.
    Understand, I am NOT referring to the extremely high pressures often used by "hypermilers" (the 50+ comment above).
    But going over the sidewall stamp is not going to cause the sky to fall as many would have you believe.
    I've been running at or slightly above (5-10psi) above sidewall max for 20 years. I run my Tacoma tires at 40psi (215/70-15, 5-lug).
  11. Sep 9, 2012 at 6:25 PM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Interesting... :popcorn:
  12. Sep 9, 2012 at 6:31 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I run 50 psi with even wear.
  13. Sep 9, 2012 at 6:35 PM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    i run 40 on 265/75/16 duratracs, no real complaints here. i also drive like im in nascar...
  14. Sep 9, 2012 at 6:36 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    When I had got my truck the dealer had it down to 29 psi. I checked them not long after and because it was winter the psi went down to 20. I had upped it to 36 and my mileage went up. I was going from 420 kms a tank to 480 kms a tank, while running 87 octane.
    Check on the side of the tire and see what the manufactures suggest. That's my best recommendation.
  15. Sep 20, 2012 at 2:52 PM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    In my truck Manual, it recommends that you increase the recommended tire pressure by 3 PSI front and rear if you drive above 100 MPH (But not exceed the pressure on the side of the tire). How many people drive their Tacoma's above 100 MPH?
  16. Sep 20, 2012 at 5:55 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    There's one or two people here that drive the autobahn from time to time. I imagine cruising at 4000 rpm in 6th gear would make about 150 miles to empty :p
  17. Sep 20, 2012 at 5:59 PM
    iroh
    michigander
    tonneau
    I'd recommend mid 30s for BFG AT tires too. LT tires aren't built like radials. It's the P-rated tires that you can run 50 psi and still get even wear year after year.
  18. Sep 21, 2012 at 6:46 AM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    You can fvck around with chalk or just use this
