Air pressure in 10 ply tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Codys9469, May 14, 2020.
  1. May 14, 2020 at 3:28 PM
    #61
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Analysis Paralysis....
    jwctaco, cubie and BravoSix like this.
  2. May 14, 2020 at 3:30 PM
    #62
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Diameter is measured unloaded; in the air.
    Junkhead and BravoSix[QUOTED] like this.
  3. May 14, 2020 at 3:31 PM
    #63
    BravoSix
    BravoSix Well-Known Member
    2017 MGM SR5 DCSB 4x4
    Seat jackers, Tonneau, Toyo AT3 235 85 16.
    Ah
    Junkhead likes this.
  4. May 14, 2020 at 3:31 PM
    #64
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    :evil:
    BravoSix[QUOTED] likes this.
  5. May 14, 2020 at 3:36 PM
    #65
    splitbolt
    NW Arkansas
    I'll chalk you up as a loss then.:p
    Interbeing, Mike O, BravoSix and 2 others like this.
  6. May 14, 2020 at 3:38 PM
    #66
    BravoSix
    Apologies to the OP for highjacking...
  7. May 14, 2020 at 3:57 PM
    #67
    splitbolt
    NW Arkansas
    Just wanted to add...
    A tires footprint increases way more longitudinaly than laterally when 'underinflated'.
    BravoSix and Junkhead[QUOTED] like this.
  8. May 14, 2020 at 3:59 PM
    #68
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    100 psi
    BravoSix and Junkhead like this.
  9. May 14, 2020 at 4:20 PM
    #69
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Interesting, never thought about that. Does make sense though.
  10. May 14, 2020 at 4:21 PM
    #70
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Is that for optimum fuel efficiency?
    BravoSix likes this.
  11. May 14, 2020 at 4:31 PM
    #71
    jowybyo
    Joe
    Baltimore, MD
    no. 103.4psi for the best mpg’s.
    Junkhead[QUOTED] and BravoSix like this.
  12. May 14, 2020 at 4:33 PM
    #72
    BravoSix
    Bartender!
  13. May 14, 2020 at 4:43 PM
    #73
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Thank you! I was looking for a little mpg bump.
  14. May 14, 2020 at 4:53 PM
    #74
    Sungod
    Sungod Well-Known Member
    St Augustine
    The problem with it just as @Mrtacoman88 shows and as @splitbolt said, looks can be deceiving. That is the problem with using chalk. While people have done it for years, it doesn't mean that it works. With 10 ply tires and 2 of those plys being steel belts, your tread remains flat over a vast PSI range. On top of that, the shape that your tires have 2mph is different than they are at 70mph. You get a fair amount of distortion as they spin. This is why putting chalk on your tires is pointless. In the old days when people ran bias ply tires, they would shape like balloons when you put more air in them and you could actually lift the side walls off the ground and run only the middle of the tread with enough air. To do that with a 10 ply steel belted radial, you would need to approach the 300psi range to get that kind of distortion.
    Now as for heat, you would start by measuring the temp across the face of the tire. From there you would determine the temperature you measure to what you are trying to achieve. In theory the temp should be the same all the way across and as you increase pressure, you should see a decrease in temperature. It is much more complex than that, but that is the way to do it.
  15. May 14, 2020 at 4:54 PM
    #75
    Sig45
    Mark
    Maine
    How does a load range C (6 ply equivalent) fit into the math here? Asking for a friend.
    I digress.....
    Junkhead and BravoSix like this.
  16. May 14, 2020 at 4:55 PM
    #76
    BravoSix
    Me too lol
    Junkhead and Sig45[QUOTED] like this.
  17. May 14, 2020 at 4:57 PM
    #77
    BravoSix
    Well
    I'm running 40 or 42 depending on the day bc it makes me happy and it's my money hahah . Cheers!
  18. May 14, 2020 at 4:59 PM
    #78
    Sig45
    Mark
    Maine
    Let's se
    32-34 seems to my sweet spot.
  19. May 14, 2020 at 5:01 PM
    #79
    BravoSix
    But 42 gives me more ground clearance for the home depot parking lot lol
  20. May 14, 2020 at 5:02 PM
    #80
    Sig45
    Mark
    Maine
    That's certainly important. I don't judge.
