Air pressure in 10 ply tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Codys9469, May 14, 2020.
  1. May 15, 2020 at 3:36 PM
    #101
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I'm not an expert on pressure gauges, but I can't imagine one that would read different based on altitude. Pressure is pressure. A torque wrench doesn't have to be calibrated for altitude. Temperature maybe, but marginal difference. That said, using a quality gauge is advised. I ride mountain bikes with fat, tubeless tires, and accuracy at lower pressures is important. Using the same quality gauge for comparison is also advised, don't switch gauges.
  2. May 15, 2020 at 3:49 PM
    #102
    BravoSix
    BravoSix Well-Known Member
    2017 MGM SR5 DCSB 4x4
    Seat jackers, Tonneau, Toyo AT3 235 85 16.
    I bought a $9 digital POS guage from auto zone today and it said every tire in my driveway was 41.5 lbs lol. Took it back and got an old school pocket pen style one and it is more accurate.
    Junkhead likes this.
  3. May 15, 2020 at 5:36 PM
    #103
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    @splitbolt
    So i took the measurements.
    • Distance between lowest part of rim to ground is 5".
    • Distance between the highest part of rim and top of tire is 5 3/4"
    • Distance on the left and right side, from rim to tire is 5 5/8"
    Now from my understanding the distances between top of rim to the tire to the lowest part of the rim to the ground should not be the same, as the tire is under load. I guess i should put a few more psi. Ill try 34 front and 32 rear and see how it feels.
    Thanks for all the info man, i havent got a chance to look at the charts though. I am really curious about it actually, ill do it this weekend for sure. Happy friday all!
    stun gun and splitbolt like this.
  4. May 15, 2020 at 5:37 PM
    #104
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Haha! I got the pen style for like 8 years now and it still works great. I would never trust a digital POS.
    BravoSix[QUOTED] likes this.
  5. May 15, 2020 at 5:45 PM
    #105
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Yes; a certain amount of deflection is to be expected. My point was...don't go by your eyeball.
    You might be surprised...
    It seems counterintuitive, but 41 psi might actually feel better.
    Junkhead[QUOTED] likes this.
  6. May 15, 2020 at 5:48 PM
    #106
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    I was a bit surprised actually.
    41psi cold?
  7. May 15, 2020 at 5:50 PM
    #107
    splitbolt
    NW Arkansas
    Yes.
  8. May 15, 2020 at 5:57 PM
    #108
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Damn. So when they heat up, it will go up to 43-44psi?
  9. May 15, 2020 at 5:59 PM
    #109
    BravoSix
    Yup
  10. May 15, 2020 at 6:19 PM
    #110
    FireRoadFan
    FireRoadFan Well-Known Member
    New Mexico
    2018 Tacoma TRD Pro
    Options on the truck delivered to the dealer: All-Weather Floor Liners Door Sill Protector Door Edge Guard Mudguards Spare Tire Lock Wheel Locks Added by me: Diamondback HD Tonneau Cover Rigid Industries 2016-2017 Toyota Tacoma Bumper Mount (SKU: 46565) Rigid Industries SR-Series Pro 30" Spot/Drive Combo (SKU: 931314) LT235/85R16 DISCOVERER S/T MAXX
    Based on your comments, I decided to make sure I was right. Here is one article indicating what I am saying makes a difference..
    https://www.tirerack.com/tires/tiretech/techpage.jsp?techid=167
  11. May 15, 2020 at 6:26 PM
    #111
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Hm. I will try and see how the ride is. Will report back tomorrow as i got the work truck again tonight, working tomorrow :sadviolin:
    Well i shouldnt complain, i should be happy i got work, ha!
  12. May 15, 2020 at 6:39 PM
    #112
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Clicked into this thread to see a jar of pee. Ambiguous jar of pee is ambiguous
    0xDEADBEEF likes this.
  13. May 16, 2020 at 7:56 AM
    #113
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Yes, if you change nothing and take a reading at 5,000 ft, and then at sea level, you will get different readings due to ambient air pressure. This has nothing to do with the gauge calibration and everything to do with ambient air pressure.
    FireRoadFan[QUOTED] likes this.
  14. May 16, 2020 at 9:00 AM
    #114
    Pb12in
    Pb12in Well-Known Member
    Keith
    San Diego
    2020 4WD MT
    A silly millimeter higher
    I don't understand why less contact patch is better. Going by the methodology detailed above, LT tires require more pressure than passenger tires. LT tires also have stiffer sidewalls/tread than passenger tires. Both of these characteristics lead to less contact patch for the same size tire and load.
  15. May 16, 2020 at 11:39 AM
    #115
    FireRoadFan
    New Mexico
    2018 Tacoma TRD Pro
    I don't mean this to be a back and forth. Here is another article discussing the difference between Gauge and Atmospheric pressures.
    https://www.coyoteents.com/compensating-tire-pressure-readings-for-elevation/?
  16. May 16, 2020 at 12:14 PM
    #116
    splitbolt
    NW Arkansas
    No it doesn't.
  17. May 16, 2020 at 2:50 PM
    #117
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    34-37 and you will be fine.
  18. May 16, 2020 at 5:08 PM
    #118
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    So i did 36 front and 34 rear and it feels the same. I dont know why i said 35 psi felt rough. It was 2 years ago and maybe it was 45 psi? Not sure, but anyways it feels good. Will look into those charts and might adjust pressure later on.
    Thanks for all the good input guys, cheers.
    :cheers:
  19. May 17, 2020 at 7:16 AM
    #119
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
