Air Pressure offroad question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truky!, Jan 21, 2023.
  1. Jan 21, 2023 at 1:54 PM
    Truky!
    Truky! [OP] Well-Known Member
    Satellite Beach FL
    2021 TRD Offroad
    When I got my wheel/tire package, I was more concerned with looks/style. Now after having it for a while, I'm to the point where I'm looking to go offroad with it. I've had previous tacos, and never had rims bigger than 16's, this is when I was in colorado.
    I'm in Florida now, and not much real off-road places, other than sand. Deep sand, I now have 20's, with 35x13.5 SST Pro's. Anybody on here aired down using 20" wheels? What did you go down to???
  2. Jan 21, 2023 at 2:09 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    If you have 20" wheels, do what those wheels were made to do: Look pretty on the concrete/asphalt roads. Keep that thin side wall-mall crawling machine of yours off the sand.
    It has no business there.
    rainsux, Tocamo, mic_sierra and 6 others like this.
  3. Jan 21, 2023 at 2:29 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    You aren't going to be able to air down 20's enough to do any good and you will likely pop the bead trying.
    rainsux, hiPSI, J Williams and 3 others like this.
  4. Jan 21, 2023 at 4:17 PM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    That's what I was afraid of... should have used common sense..
    Tocamo, Chew, bulalo and 1 other person like this.
  5. Jan 21, 2023 at 4:21 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Pavement only.
    mic_sierra, Borracho Loco and Chew like this.
  6. Jan 21, 2023 at 4:37 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
  7. Jan 21, 2023 at 5:04 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    You have just as much sidewall as a limited from the factory. I say air down to about 20 and see how it does. You won’t pop a bead in sand. I wouldn’t rock crawl with it.
    Junkhead likes this.
  8. Jan 21, 2023 at 5:45 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You could definitely air down to about 20 psi, just be careful not to damage the rims off-road.
    hiPSI likes this.
  9. Jan 21, 2023 at 5:59 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Good luck but width is also working against you.
    With my stock 16's I air down to 12-15 psi with confidence. 20 ish but be careful! No logs or rocks.
    Casey182 and Junkhead like this.
  10. Jan 22, 2023 at 10:14 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Yeah, on my white one I had 285's on the stock wheels, and would go down to 15, never had an issue. Thinking I might get some 17 SCS blems and sell what I have now...
  11. Jan 22, 2023 at 10:25 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    Good discussion over here on the Jeep Garage. If the internet is to be believed, the two things you should be concerned with is bending the wheel on hard surfaces (not a factor if you are in the sand and air back up before you get back on the hard stuff) and there not being much sidewall to protect the wheel when aired down.
    Test it out in the soft stuff at something conservative like 20 - 25 psi and stay out of the sugar sand and watch for the hard stuff. If you hit some hard pack between the sand slow it way down so you're not putting too much load on the tires (risking bending the wheels) from the load of the terrain. You should be fine - just expect your TPMS lights to stay on until you air back up and FOR SURE air up before you hit the asphalt.
    My $.02.
  12. Jan 22, 2023 at 11:23 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Thanks for the link!!
    mic_sierra[QUOTED] likes this.
  13. Jan 22, 2023 at 11:41 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Get yourself some cheap '16 or '17 steel rims, and a good set of Off Road tires. I love my A/T Duratracs, but in this case I'd get a serious set of M/T's. (No need for sensors, if your just using them to play off road with)
    That's what I would do after slapping myself silly for getting 20" rims.... :jpow:
  14. Jan 22, 2023 at 11:44 AM
    Truky!
    Satellite Beach FL
    2021 TRD Offroad
    Looking into that right now hahaha
    Tocamo[QUOTED] likes this.
