Air Pressure
Discussion in 'Wheels & Tires' started by kilroy2963, Sep 1, 2024.
  1. Sep 1, 2024 at 9:35 AM
    kilroy2963
    kilroy2963 [OP] Well-Known Member
    Massachusetts
    2008 Blue TRD Offroad
    So what do you typically run in your 2nd gen Tacoma AT tires for regular day to day driving? I have been running 30/30 myself.
  2. Sep 1, 2024 at 9:53 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If your running standard P tires in the factory size you should be close following the sticker on the door, if your running LT tires you will probably need to run a higher pressure.
  3. Sep 1, 2024 at 9:56 AM
    kilroy2963
    Massachusetts
    How do I know if it's P or LT, is it on the tire?
  4. Sep 1, 2024 at 10:05 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Should say it on the tire, P tires will typically have a P or nothing before the tire size (P265/70R16) and they will say standard load.
    LT tires will typically have LT in front of the size (LT265/60R16).
  5. Sep 1, 2024 at 11:33 AM
    kilroy2963
    Massachusetts
    I have a set of General Grabber ATX's, and the size just reads 265/70R16
  6. Sep 2, 2024 at 6:42 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Those look to be standard load P rated tires so I'd say just following the pressures on your door tag should be fine.
