Air Pump loud after CAI mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jakefarley, Mar 8, 2017.
  1. Mar 8, 2017 at 11:57 AM
    Jakefarley
    Jakefarley [OP] Member
    Florida
    2012 Tacoma Prerunner
    About a year ago I installed a CAI and had to relocate the air pump. The rubber grommets that isolated the pump from the engine compartment were not reused and a new bracket was supplied by the CAI manufacturer K&N. Ever since, when starting the engine, the air pump is loud until it shuts down. I installed rubber washers on the bracket but that did not help. Anyone else have this problem and what did they do to remedy?
    Thanks!!
  2. Mar 8, 2017 at 3:58 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    A fundamental design criteria for OEM engineers is called NVH (Noise, Vibration and Harshness). It is a consideration even if it increases production costs. Aftermarket "performance" makers do not place as high an emphasis on NVH, especially if it increases costs.
    Got any photos of the relocated air pump--maybe the good people here can offer some words of wisdom?
    Txexplorer likes this.
  3. Mar 8, 2017 at 5:12 PM
    Jakefarley
    Florida
    Below is a pic of the install. As you can see the air pump is crammed in the front of the engine compartment next to the washer reservoir. It is contacting the reservoir (at the seam) and that most likely makes it louder. I will move it so it does not contact the reservoir and that will probably lessen the noise.
  4. Mar 8, 2017 at 5:33 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    We used to call those various things K&N makes "HAIs" (Hot Air Intakes). The stock intake is a true CAI (Cool Air) drawing air exclusively from the fender well, and is tuned to match the engine's intake flow dynamics as well.
    I agree with your assessment/plan, isolating the air pump from contact with anything, as much as you, can will minimise the noise...
  5. Mar 10, 2017 at 1:43 PM
    Jakefarley
    Florida
    I may consider replacing it with the stock air intake. It does seem to add horsepower, but maybe it is the sound deceiving me...:)
  6. Mar 10, 2017 at 2:08 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    The placebo effect of most aftermarket "CAI" kits is remarkably powerful, more often than not it's the most powerful thing about them...
  7. Apr 22, 2021 at 1:55 AM
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    This may or may not be an old post, but I just recently reinstalled the factory box, with a K&N factory like filter, but replaced the accordion style hood with a straight pipe mod in 3" diameter. Wrapped the tube with heat wrap, and stuck the opening of the tube through the fender air opening. It feels re-tuned and in sync more so than with the K&N cai. I'll run this for a while, but almost instantly noticed better mpg's.... I'll post a couple of pics if this post requests????
    Marc70 likes this.
  8. Jun 13, 2021 at 8:04 AM
    Sassy's dad
    Sassy's dad Member
    Norb
    2007 PreRunner
    Pics please
