Air Ratchet and Impact Wrench
Discussion in 'Recovery' started by Kwikvette, Jul 15, 2019.
  1. Jul 15, 2019 at 8:35 AM
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    So I have co2 as my onboard air and one thing I'd like to do is buy an air ratchet as well as an air impact wrench (for lug nuts, so nothing with excessive torque?).
    Posted this elsewhere but received no traction (no pun intended).
    Again, I'm looking for those that use onboard air and use their tools for quick fixes off road.
    Been looking at the Craftsmen Air Ratchet, but unsure on an impact wrench to buy?
    The impact wrench could either be somewhat variable, or provide just enough torque for undoing and putting on lug nuts. Asking here since I have many tools, but I'm completely new to air tools.
  2. Jul 15, 2019 at 12:08 PM
    Tacoma Mike
    Southern Maine
    Couple of guys use craftsmen impacts in my shop. They get the job done for tires etc.
    Kwikvette[QUOTED][OP] likes this.
  3. Jul 15, 2019 at 12:11 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Dewalt makes great battery powered impacts if you have a few bucks to spend.
  4. Jul 15, 2019 at 12:12 PM
    Tacoma Mike
    Southern Maine
    He wants air powered as he has onboard
    Kwikvette[OP] likes this.
  5. Jul 15, 2019 at 12:13 PM
    LivinOnEdge
    Land of The Lost
    I understand, just recommending another product.
  6. Jul 15, 2019 at 12:19 PM
    Tacoma Mike
    Southern Maine
    I have their 3/8 impact and drill
    No prob with them so I imaging the 1/2 would give the same service
    LivinOnEdge[QUOTED] likes this.
  7. Jul 15, 2019 at 12:23 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I use a cheap harbor freight air wrench in my truck. Main problem with air tools, they go to shit if you don't keep them lubed and use them frequently.
    Gunshot-6A and LivinOnEdge like this.
  8. Jul 15, 2019 at 12:24 PM
    LivinOnEdge
    Land of The Lost
    Again, not docking OP for his need of air tools but just something to keep in mind. Brushless impact wrenches are truly amazing.
    Gunshot-6A and rob1208 like this.
  9. Jul 15, 2019 at 12:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Looking at the torque spec for a 1st gen's lug nuts, I only need 84 ft/lb of torque so an impact should be a no go.
    I'll just go with an air ratchet.
    I do have powered tools, but no impact wrench in my arsenal; I've always used a breaker bar and arm strength for all my vehicles.
    SR-71A and LivinOnEdge like this.
  10. Jul 15, 2019 at 12:26 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Also consider the CFM requirement of those tools and the capacity of your tank. You're still up a creek if you depleted your CO2 tank using the air tools, and cant air up the tire you just repaired..
    truckbeans and LivinOnEdge like this.
  11. Jul 15, 2019 at 12:26 PM
    LivinOnEdge
    Land of The Lost
    Nothing wrong with old school! Sorry I couldn't provide any information for your application.
  12. Jul 15, 2019 at 12:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've seen the Dewalt impact wrench that's posted throughout the forum, and have read great things about it.
    In fact, a few of my guys in our shop have the same impact wrench; I just wanted to check out an alternative for use on air.
  13. Jul 15, 2019 at 12:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yes good point; I already have plans to buy a second tank (10lb) just for that reason.
    I'll be using my 5lb tank exclusively for airing tires up and a 10lb for everything else.
  14. Aug 28, 2019 at 11:58 AM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    not knocking on air, but the 18v impacts out now are over 400ftlbs... air tools are heavy and use a lot of wir.. and for a co2 tank they get cold and freeze the regulator flowing that much.. for $180 +/- tax...
    https://www.homedepot.com/p/RIDGID-...attery-and-18-Volt-Charger-R86011SB/303037082
    and its far more usefull and veratile around the house too.. other brands make similar styles, and torque bits, all depends on what you have for batteries already, and if you are sticking with that system..
    one thing to keep in mind if you want to keep it for a while, and use it heavily is that the hog ring, (not the detent ball) on the impacts last longer. and typically the ring retention mechanism is a LOT stronger especially if you watch any type of tool torture testing..
    I'm looking at the ridgid as I already have the setup for an 18v drill (got them on special for $79 for a 18v hammer/drill 2 batteries and a charger...). but I may get the Milwaukee as I already have the M12v impact, and ratchet (theyre super nice, and compact, I pack them in my repair/tools kit).
    Lord Helmet and BKinzey like this.
  15. Aug 29, 2019 at 7:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thanks for the advice, but I will go as far as say you are wrong about the regulator freezing.
    I'll be purchasing a battery operated impact for those longer drives.
  16. Aug 30, 2019 at 7:07 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Wait for the sales. They offer around 40% off, free extra batteries, BOGO, other offers. Home Depot offered the best price, had to order on line :)confused:) for the kit I wanted with free delivery. I bought a Milwaukee 18v 9 tool brushless (Fuel model) motor kit for $600, regular price was $1,000. Last Black Friday sale. I spent a couple of hours searching over a few days. Home Depot had the best price.
    Did I mention Home Depot? Oh goodie! :bananadance::dancingbacon::broccoli::kona::taco: Now I get to Bitch & Moan about them!:rant: They offered free delivery to my home or local Home Desperate. I live in Los Angeles so I didn't want a huge red box with "Milwaukee Tool Kit" emblazoned on it left on my doorstep. So I asked for delivery to the local store. My house was 4 days estimate. Estimated delivery to the store was 6-8 days. :jerkoff: It took 8 days.:mad::rolleyes:
  17. Sep 1, 2019 at 2:45 PM
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    co2 regulators freeze regularly... not my vid but just look at the regulator..
    https://www.youtube.com/watch?v=UF9eBkAodps
    when they freeze up they tend to stick open, and if you disconnect your quick fitting it can continue to leak. just something to look out for. but super nice to make a warm beverage cold.... lol.
  18. Sep 7, 2019 at 4:11 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    What I bought for my 3/8" ratchet off road repairs and 3/8" impact for the wheel removal. Both are part of my off road/recovery bag. I have a 1/2" impact but the weight of that thing is too much with muscle fatigue a main point on why I pulled it from the recovery bag.
    55 ft-lbs 3/8" ratchet:
    https://www.amazon.com/Milwaukee-Lithium-Ion-Brushless-Cordless-Batteries/dp/B077F76VGT
    For my 3/8" impact wrench: 450 ft-lbs fasting torque and 600 ft-lbs removal torque.
    https://www.amazon.com/dp/B07JR8TFNB/ref=psdc_552820_t3_B077H7JP1D
  19. Sep 7, 2019 at 4:15 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    Harbor Freight Earthquake air impacts are just fine for occasional use, I used one in a shop for about a year and half of daily use and never had a problem.
    Milwaukee 3/8'' electric ratchets are dope, I love mine. The Fuel version would be even better if you want it for trail use. I will chime in also and say the Milwaukee 1/2'' M18 battery impact is amazing and it has just as much if not more torque than my HF air impact.
  20. Sep 7, 2019 at 4:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    My regulator has never frozen up, and I've messed with it a lot to finish up the remaining co2 that was in it before I got it filled up again.
    There was a lot of "frost" on the outside of it but it never got stuck "open".
