Air ride?
Discussion in 'Suspension' started by dvolk2, Jun 18, 2015.
  1. Jun 18, 2015 at 11:05 AM
    dvolk2
    dvolk2 [OP] Active Member
    David
    2015 xspx
    Stock for now
    Is anyone running air ride suspension? If so how do you like it and what range of travel? Does it work for offroading?
  2. Jun 20, 2015 at 7:52 AM
    Pigpen
    Dan
    Northwest Montana
    I'll post, since you aren't getting any love.
    I have Firestone RideRite air bags, not Air Ride. Close enough. I love them.
    I do a fair bit of light offroading and lots of shitty dirt road driving. The quick rebound of the inflated bags rapidly ate my rear stock shocks. I replaced them with OME N182 shocks and am very happy with the ride on and off road.
    Inflated air bags will limit the up travel of your suspension and give a firm rebound on harder hits - and will bounce pretty bad when your shocks are dead.
    I installed air bags because I wasn't lifted at the time and just needed to get rid of the sag while towing and hauling. When I put in 5100s at 1.75 (actual lift = 2.5), I just filled the bags to 35 to keep factory rake - ride wasn't bad for a few thousand miles. I figured I'd add the Emu shocks because eventually I'd add Dakars. Well, my dirty little secret is that I'm in no hurry to do rear leafs - I'm still happy enough with the ride as is. Rear springs are pretty far down my list of intended mods now.
  3. Jun 20, 2015 at 7:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Are you asking about bagged (slammed/stanced) trucks?
    Or air bags for auxiliary cargo capacity?
  4. Jun 26, 2015 at 6:03 PM
    dvolk2
    David
    2015 xspx
    Stock for now
    I'm actually talking about airbag systems to lift your truck. I know kelderman makes a system for ford, chevy and I think dodge but I haven't been able to find any setups for the tacoma. I would assume it would help with suspension travel for off roading, firming up the suspension when towing and probably enhance overall ride quality. Not to mention most people don't have it so it would be cool amd unique.
  5. Jun 26, 2015 at 6:05 PM
    dvolk2
    David
    2015 xspx
    Stock for now
    Yes I have seen these setups but I want something a little more dramatic that might give about 6 inches of lift. Thanks for the reply though.
  6. Jun 26, 2015 at 6:07 PM
    Pigpen
    Dan
    Northwest Montana
    If you want a 6 inch lift, you have to do a drop bracket. The IFS won't handle over 3.
  7. Jun 26, 2015 at 6:10 PM
    dvolk2
    David
    2015 xspx
    Stock for now
    Yeah that's about all I could find. Probably buy a procomp lift for christmas.
  8. Jun 26, 2015 at 6:14 PM
    Pigpen
    Dan
    Northwest Montana
    The good news is that it won't eff up your cv angles and you are less likely to have needle bearing issues. I've got a buddy on a 6 inch db and 35s. Looks great.
