Air shocks as secondary shocks for towing?
Discussion in 'Suspension' started by Watermallon, Nov 29, 2023.
  1. Nov 29, 2023 at 4:56 PM
    Watermallon
    Watermallon [OP] ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    Anyone ever used Air shocks in conjunction with your normal shocks as help for towing/hauling?
    My leaf springs are not meant for towing, and my wife and I want to try and get a teardrop camper. I know they don’t weigh a lot but I want to keep my leaf pack and prolong its use.
    I was thinking, would it be possible to fab up a crossbar under the bed, behind the rear axle to mount air shocks to, and just bolt them on and fill up with a compressor when needed? That way you can take them off and store them when not in use. Or is this idea just too much for a simpler solution lol
  2. Nov 30, 2023 at 6:37 AM
    Toolndie7
    Toolndie7 Well-Known Member
    2019 Sport DCSB Cavalry Blue
    Why not just use airbags ?
    koditten likes this.
  3. Nov 30, 2023 at 7:27 AM
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    Don’t airbags stay on even when not in use? Or are they easy to remove and install for only when you need them?
    Rexfordian13 likes this.
  4. Nov 30, 2023 at 7:30 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    It's been done on other vehicles (Raptors/Chevy 1500) and I think it's a good idea. I've never seen anyone do it on a Tacoma but the same concepts apply.
  5. Nov 30, 2023 at 7:30 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    You just air them down when you don't need them.
    Wulf, koditten and YF_Ryan like this.
  6. Nov 30, 2023 at 7:32 AM
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    True but my bump stop is where bags would go so then I’d essentially have no bump
  7. Nov 30, 2023 at 7:33 AM
    Rexfordian13
    Rexfordian13 Well-Known Member
    J
    Albany/NY Capital District
    2015 TRD Sport DCSB MT
    Airbags are designed to be left on, they’re pretty compact, mount easily and don’t weigh much. Hook up the trailer and add some air until level, deflate to less psi when not towing.
    hr206 and YF_Ryan like this.
  8. Nov 30, 2023 at 7:34 AM
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    I’m wondering if shock orientation would be an issue because there’s not much room with the gas tank in the way for them to face forward, so the top of the shock would be rearward of the axle.
  9. Nov 30, 2023 at 7:34 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    As @joeyv141 said, you just air them down to the minimum pressure. They shouldn't change your ride quality significantly at that pressure.
    You can't just take them on and off easily either, as you (on the kits I know) have to cut the bump stop off, or unbolt your axle u-bolts and remove it/put it back on every time. And you shouldn't be re-using U-bolts, so that would get expensive fast.
  10. Nov 30, 2023 at 7:52 AM
    desertjunkie760
    Shane
    Check My Sig.
    Factory mounts on the Tacoma have one shock facing forward & one facing backwards to minimize axle wrap. Most aftermarket relocation kits put the shocks forward as it's most beneficial for suspension geometry from a performance aspect.
    I would think that mounting the air shocks backwards would be fine as they're just being used to help with the additional load. They'll be removed when you want to really use the travel.
  11. Nov 30, 2023 at 7:56 AM
    YF_Ryan
    Kent, WA
    I hate my life right now... how the F do you get strike through to work on here!!!:thumbsup:
  12. Nov 30, 2023 at 7:59 AM
    545 Well-Known Member
    2015 Access Cab
    I don’t believe any standard airbag kits for Tacomas 05-23 have bump stops in them
  13. Nov 30, 2023 at 8:01 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    True, you have to remove the bump stops. The air bags are mounted in their place. The aired down bags are now your bump stops.
    I have air bags. I love them. I leave 2 psi of pressure in my bags when not hauling or towing. I don't miss the bump stops.
    My next truck is getting air bags as well.
    joeyv141 and Rexfordian13 like this.
  14. Nov 30, 2023 at 8:11 AM
    YF_Ryan
    Kent, WA
    Thanks, edited my post. Apparently I had read about the Airlifter's, not the Firestones.
  15. Nov 30, 2023 at 8:12 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I used Firestone Ride-Rites on my 2nd gen and have them on my 3rd gen, love them. They just take the place of the bump stops. The guidance is 1 psi for each 40 lbs. of weight, which I have found pretty useful. I estimate the weight, divide by 40, and add 5 psi to that. If you have to go over the max, you are probably overloading the truck severely.
  16. Nov 30, 2023 at 8:39 AM
    Toolndie7
    Watermallon[OP] likes this.
  17. Dec 2, 2023 at 5:23 PM
    9pm
    9pm Well-Known Member
    Just a suggestion, also look in sumo springs.
  18. Dec 2, 2023 at 6:29 PM
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    Exactly what I had pictured in my head. Just didn’t know if it would be overkill lol
