Air soft bbs/ tire balancing
Discussion in '1st Gen. Tacomas (1995-2004)' started by shawnster88, Aug 5, 2018.
  1. Aug 6, 2018 at 7:01 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I use Ride-on in my motorcycle tires. Got the shop to add it before they mounted them. I have a 90/90-21 up front and a 230/60-15 in the rear. I think it took about 24 oz total between the two tires. Added benefit of puncture seal if I get a nail.
    http://www.ride-on.com/
    I've thought about adding to my current S/T Maxx as I can feel a shimmy at higher speeds but haven't yet.
  2. Aug 6, 2018 at 8:13 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I used airsoft bb's on my swampers (step by step in my build thread with what I did). They worked some of the time, it was weird. Saying that I eventually got rid of the tires as they would bounce down the highway they were so out of round. Currently running toyos on beadlocks with no weights and all is well! Talked to my local discount tire and they said they can balance 37s on beadlocks so if they start sharking, im taking it there and not messing with BBs again.
  3. Aug 6, 2018 at 8:47 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    'Dyna-Beads' was the original I believe, always heard mixed results. Slower speeds seemed fine, highway speeds most people went back to regular balancing.
    I guess it's one of those "If all else fails" things.
  4. Aug 6, 2018 at 8:54 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Wyoming09,
    If you scroll down to "4. Answers", and read sections 3-5, it gives some clues as to why the things you mention might be occurring. It takes wheel bounce and changes in the centrifugal force acting on the beads to give them a chance to move to the correct (light) position in the tire. Basically, if you take off and drive on a completely smooth road at a constant speed, that is worst case for the beads being able to react. A bumpy road, with some changes in speed, allows quickest adjustment by the beads.
    https://engineering.stackexchange.com/questions/6015/how-do-tire-balancing-beads-work#6059
  5. Aug 6, 2018 at 9:14 AM
    Wulf
    rock raisin
    I had a similar experience! I had 38.5 Swampers (bias ply) on my Jeep in high school. They balanced ok but between flat spots and out of round they sucked above 45mph.
    I have a set of Toyos on Allied beadlocks with beads on my current Jeep and they run smooth at all speeds.
  6. Aug 6, 2018 at 9:17 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    RideOn is what I use in my Valkyries now. My 2014 Valkyrie's front wheel is so out of balance,
    that I can't balance the front with (any reasonable amount of) RideOn. I ended up balancing the
    wheel with a static balancer and weights, now the RideOn there is just for flat protection...
    They make RideOn (see the link) for cars and trucks too...
    -Mike
  7. Aug 6, 2018 at 10:04 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    that's actually odd as most motorcycle tires require less balancing. I got lucky with my Avons
  8. Aug 6, 2018 at 11:35 AM
    hubcapsc
    My tire's not unbalanced, my wheel is... I static balanced the wheel with no tire.
    -Mike "There's an Avon on there now..."
  9. Aug 6, 2018 at 11:57 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    Yes, I have airsoft BBs in my tires. They do make some noise at starts and stops or if you are rolling along under 10MPH. Other than that, no issues.
