Air tank
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WunderSlug, Mar 10, 2019.
  1. Mar 10, 2019 at 6:48 AM
    WunderSlug
    WunderSlug [OP] Well-Known Member
    '17 QS DCLB TRD OR
    So, my buddy picked up a sweet Viair compressor for me off of an old ambulance for free. Now my question is, how to build/buy an air tank on the cheap.
    I was thinking of PVC since, it's a. cheap, b. strong, and c. meant to last forever. Schedule 40 4" is rated to 220 psi, so a regulator set to 100 psi, should be sufficient. And, yes, I've read all the warnings about not using it for this purpose, so I'm well aware.
    So with that out of the way, has anyone successfully done this? And mind you, the only thing this will be used for is inflating bike tires, matresses, etc. I won't be using this for tires, etc.
  2. Mar 10, 2019 at 6:54 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Will this be a portable tank? Can’t see it being much use for such a small volume of air as needed for an air mattress or bike tire if the compressor itself is within reach.
    Just to throw it out there, in case you missed it, pressure cycling pvc is going to weaken it substantially over time.
    Edit: never done this, to answer your question.
  3. Mar 10, 2019 at 7:49 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Absolutely NEVER use PVC as an air tank. That is a literal ticking time bomb. I’ve seen too many PVC pipes explode under air pressure. PVC as a water tank? Sure, pressurized water doesn’t have nearly as much energy as pressurized air. Use steel
    shakerhood likes this.
  4. Mar 10, 2019 at 7:54 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    A real air tank is as cheap as $30.
    shakerhood, Boghog1 and Anchovy like this.
  5. Mar 10, 2019 at 8:06 AM
    knydecker
    knydecker Member
    Timothy
    2017 Toyota Tacoma TRD Offroad
  6. Mar 10, 2019 at 9:05 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    In terms of tanks.... NEVER use PVC.
    There are plenty of 'kits' online to buy tanks that are already prepped and ready to hook up - depending on the size you want / need. Or - if you have access to some old CO2 tanks, or old tanks from scuba shops, etc..... you can retrofit those.
    We had a CO2 tank cut down to size - caps rewelded - bungs cut & welded in. This was mounted in our jeep.
  7. Mar 10, 2019 at 5:11 PM
    WunderSlug
    '17 QS DCLB TRD OR
    Ok, I'll pass on the PVC. Turns out I never needed to post this anyway. My buddy has an air tank to go with it... Problem solved.
