air vent question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baldy54, Feb 10, 2010.
  1. Feb 10, 2010 at 9:50 PM
    baldy54
    baldy54 [OP] Well-Known Member
    Orlando, FL
    06 Prerunner SR5
    Hey I have a 2006 double cab, I need help with a question.. I turn on my air or heat in my truck and I select like the defrost and then I go to the floor and there is very little air coming out by my feet and it sound like it still is coming out of the defrost.. Also when I put the air to vents to to heat or cool it works fine as in coming out the vents.. SO when the air is moved to the floor it seams that little or none come out from the floor.. Does anyone know what is going on??
  2. Feb 10, 2010 at 9:53 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    unless you have it on just the floor setting then most of the air will go to the vents/defrost (if it is on font vents and floor or defrost and floor)
    its just how it is
  3. Feb 10, 2010 at 10:04 PM
    baldy54
    Orlando, FL
    06 Prerunner SR5
    I have it in the floor mode only and get hardly any air out of it. It sounds like it is still coming out of the defrost vents
  4. Feb 10, 2010 at 10:30 PM
    SoCalBlack08
    SoCalBlack08 Well-Known Member
    CA
    08 PreRunner DC
    ive experienced a problem with the heater too...when i put it on defrost it wont heat up and i have to wipe the windshield with my hands om the inside:confused:
  5. Feb 10, 2010 at 10:32 PM
    mr2crazed
    mr2crazed Well-Known Member
    Morro Bay, CA.
    06 DC PreRunner SR5
