Air vents smell funky after turning AC off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Grimble27, Apr 27, 2023.
  1. Apr 27, 2023 at 8:23 AM
    Grimble27
    Grimble27 [OP] Well-Known Member
    Washington
    '23 White Tacoma TRD OR
    New 2023 with only 1k miles. Bought it in the winter so yesterday was the first time ever turning on the AC. Everything was fine until I turned the AC off (out of habit I always turn it off a few minutes before shutting the vehicle off to help remove moisture from the system). Funky smell was coming from the vents. Didn’t ever happen with the heat on, regular air, or the one time I had the AC on, only after using the AC and turning it off. Is this normal the first few uses or is something going on I need to check? Truck is basically brand new and been parked in my garage when not driving.
  2. Apr 27, 2023 at 8:30 AM
    deaps
    deaps Well-Known Member
    2023 TRD OR
    Probably just drive it more or something. Mine doesn't smell, but I just set it at like somewhere between 68 to 72 and let it's do its thing. Whether it's blowing heat or using the AC is kind of invisible to me. I just let it do its thing. No weird smells here though.
  3. Apr 27, 2023 at 8:37 AM
    Vjustinc
    Vjustinc Talk Nerdy to Me
    City of Angels CA
    2021 Toyota Tacoma (it's white)
    Kind of similar experience but I will say it goes away after a few minutes
    davidstacoma likes this.
  4. Apr 27, 2023 at 8:40 AM
    Grimble27
    Washington
    Does yours do it every time for a few minutes or just the first time you used it?
  5. Apr 27, 2023 at 8:45 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Typically recirculate is engaged with AC and turns off with AC. Is it possible when you cut off the air, you started getting some outside smell? Or is this a more distinct, obviously something might be dead/some kind of mold type of smell coming from vents?
  6. Apr 27, 2023 at 8:46 AM
    Mtbkrguy
    Mtbkrguy Well-Known Member
    2016 Tacoma TRD Sport 4x4 Double-cab
    I would check the cabin air filter located inside the glove box. I've had mouse poop on mine before.
  7. Apr 27, 2023 at 8:47 AM
    eurowner
    eurowner Duke Sky
    Scoty
  8. Apr 27, 2023 at 8:49 AM
    Grimble27
    Washington
    Definitely a musty kind of smell. Not from random outside air smell.
    shakerhood and cryptolime like this.
  9. Apr 27, 2023 at 8:49 AM
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    Recirculate is the default mode. When some odors persist from other sources I turn up the fan and turn on "external exhaust" mode to clear out.
  10. Apr 27, 2023 at 8:49 AM
    Grimble27
    Washington
    I’ll check mine out. Seems like I’d get the smell all the time if it’s something on the air filter, but mine is distinctly only after turning the ac back off.
  11. Apr 27, 2023 at 8:50 AM
    Grimble27
    Washington
    Yep I did this. As soon as I smelled it I cranked the fan to high and made sure recirculate was off to try and clear the smell out of the vents.
    Edit: or are you saying to do this with the AC still on? I’ll try that too
  12. Apr 27, 2023 at 8:56 AM
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    This is not uncommon depending on the atmospheric conditions where you live I believe (southeast temps and humidity etc). I turn my AC off and blow warm air a couple minutes before I park. Really helps dry out moisture in the air box to prevent/minimize the smell.
  13. Apr 27, 2023 at 9:01 AM
    Grimble27
    Washington
    I’m in the PNW. We don’t have much humidity here (dry air desert climate locally).
    davidstacoma[QUOTED] likes this.
  14. Apr 27, 2023 at 9:10 AM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    Mine actually did the same thing. Turn off the the recirculation and turn the AC on full blast. Spray some Lysol in the intake vent in the bottom of the windshield. Toyota also makes a treatment for this you can buy at the dealership. I went in my local dealership and suggested it was a warranty issue. They provided me the service for free just to get rid of me.
  15. Apr 27, 2023 at 9:11 AM
    Grimble27
    Washington
    Good to know, thanks!
  16. Apr 27, 2023 at 9:12 AM
    TRD Ted
  17. Apr 27, 2023 at 9:12 AM
    RichochetRabbit
    You open the windiws of your house every now and then to let it "air out". 15 minutes a day blowing air fast though vents seems the same.
  18. Apr 27, 2023 at 9:21 AM
    Vjustinc
    City of Angels CA
    So it wasnt present initially but I just kind of noticed it a few weeks ago when I needed the AC on the way to Vegas. I hadnt used it before that/didnt need to for a few months. I'll try to see if its still happening when we drive today.
    Mine is a musty smell as well. Like clothes that havent dryed properly
  19. Apr 27, 2023 at 9:28 AM
    deaps
    2023 TRD OR
    I wonder if it's pollen.
    We get a lot of pollen here, and while I don't smell anything in mine, maybe that's getting into your cabin air system and kind of "rotting" - it's probably temporary either way.
    I don't park mine in the garage (I don't even think it would fit) - but I definitely don't drive it even every day either though. Mine will sit in the same spot for 3 days at a time before I even go back out to it, 1300 miles here, and I haven't noticed a thing. I probably will smell something next time I drive it though now lol.
  20. Apr 27, 2023 at 9:44 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    yea, mine always smells a bit after turning the A/C off. i tried doing an a/c refresh but it didn't help much. I cleaned the evaporator coils by spraying it through the drain hose. I didn't spray anything into the vents though.
