Airaid MXP CAI
Discussion in 'Performance and Tuning' started by Menj309, May 10, 2014.
  1. May 21, 2014 at 11:51 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
  2. May 21, 2014 at 1:52 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Actually, regrinds are more expensive than new grinds. By $3-500.
  3. May 21, 2014 at 3:38 PM
    tooter
    Greg
    Los Angeles
    Thanks, didn't know that. Just thought that some of the idle area of the lobes would be removed to get more relative lift and duration. It's clear I'm not a cam grinder. :tinfoilhat:
    Greg
  4. May 21, 2014 at 9:39 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I find it depends a lot on what the car started with. For example, if you put an aftermarket air box on a 400HP+ twin turbo engine, odds are the manufacture spent a pretty penny figuring out what was the optimal air-box configuration was to start with. Adding a better air flow design probably won't increase the power much, since the OEM has way more money and engineering to play with then any aftermarket manufacturer. In such a setup you're 100 percent correct, all you do is add noise and you gain next to nothing in horsepower or torque.
    Let's take a Tacoma though. The stock air intake was designed to grab air for a naturally aspirated engine. Then we go and stick the TRD supercharger under there. I won't waste my time with the math, but suddenly you have a much higher demand for air out of a system that was really designed for much less air. There's where I suspect you can make good power gains out of a CAI, or even a short ram intake.
    Or maybe I just love hearing that whine, either way it makes me happy!
