Airbag Bypass Switch
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lee_533, Nov 12, 2016.
  1. Nov 12, 2016 at 10:07 AM
    Lee_533
    Lee_533 [OP] Well-Known Member
    Andrew
    2016 Tacoma SR5 4X4
    2.5" Extended Travel King Coilovers, Camburg Uniball UCAs, Total Chaos LCAs, Dakar Leafs, Fox Rear Shocks, warn winch, Full Relentless armor, arb on board air compressor, 35” Tires
    I know a bunch of people are going to freak out that I want to bypass the entire airbag system, but I wheel my truck pretty hard and will be going to Moab for a week next year. Is there a wire I can intercept and put on a switch to disable the airbags? I hear the curtain bags run off a tilt sensor and I don't want to trigger the airbags when I'm wheeling. The off roads have a button to disable the curtain bags but I'm sitting in an sr5.
  2. Nov 12, 2016 at 10:14 AM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    Haven't looked at my fuse panel for it yet, but pull the fuse(s) would best & easiest I would guess.
    The worry is that you break / damage the sensor unknowingly then put the fuse back in and they still go off lol. Far fetched I know but still would suck.
    kahanabob likes this.
  3. Nov 12, 2016 at 10:45 AM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    I saw the fuse for the airbags. I didn't know if anyone knew what wire went to that fuse. I would like to have it on a switch so while I'm wheeling I can turn it off, and before I hit pavement I can turn it back on without having to taking the kick panel out in the cab.
  4. Nov 12, 2016 at 11:21 AM
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Maybe I am dense but where does the OR have this switch?
  5. Nov 12, 2016 at 11:26 AM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    I can't remember the term they use but it's a button that if you could it down it will disengage the curtain airbags. My buddy has it on his 15 OR. It's a solid idea considering if you're crawling and get off camber you don't want random bags blowing up lol
  6. Nov 12, 2016 at 11:47 AM
    nevadabugle
    Elko, NV
    Yeah my wife's 2010 FJ has is. but I do not believe the 2016 OR tacoma has it. I have looked.
  7. Nov 12, 2016 at 12:05 PM
    Lee_533
    Andrew
    2016 Tacoma SR5 4X4
    I wonder if it automatically turns them off when you're in 4wd
  8. Nov 12, 2016 at 5:46 PM
    Duckman
    Duckman n00b Extordinaire
    Somewhere on the River
    17 White TRD ORDC TECH 4X4
