Airbag code 14 on an 05 (clock spring/spiral cable?)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheHansen, May 21, 2011.
  1. May 21, 2011 at 10:29 AM
    TheHansen
    TheHansen [OP] Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    I can't for the life of me find the list of the codes and what each means. If anyone has it or knows this code offhand i'd appreciate it.
    Im thinking it's going to be the clock spring/spiral cable as its seems to be a common issue, but none of the threads i saw included what code they had prior to replacing it.
    If, im on the right track does anyone know how to test the clock spring/spiral cable to see if it is the problem ( i know i have to take apart the steering wheel, i've done it b4 on other vehicles in school)
  2. May 21, 2011 at 1:50 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    bump...
    anyone? i can't really afford to bring it to the dealer at the moment.
  3. May 21, 2011 at 5:45 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    It's not the spiral cable.
    Code 14 is a Front Airbag Sensor, Left Hand, Circuit Malfunction.
    It's caused by the left side airbag sensor, the center airbag sensor assembly, or the wiring between them.
    It's set if the center airbag sensor assembly sees a short, an open, a short to ground, or a short to battery voltage on the wires to the front left airbag sensor.
    There are good instructions on how to troubleshoot Code 14 in the FSM here:
  4. May 21, 2011 at 6:38 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    Wow thank you, I never expected to be able to find full repair manuals online. Exactly what i was looking for and more, i'm definitely saving that link.
  5. May 22, 2011 at 3:44 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    so, now i am getting code 14 and code 13... but both LH/RH circuits are within spec's (resistance, and voltage with key on) ... im not really sure where to go from here, i went through all of my wiring for both circuits. Every inch of both of the circuits looked free of any damage to the wire's.
    According to the repair manual, and my best guess would be that the center airbag sensor is bad. But it says to replace it and see if it works, and then if it doesn't to replace both of the front impact sensors.
    I can't find any info on this happening to anyone else... There is no visible damage to the sensor itself, or the 2 front sensors.
    The day that this light first turned on, was right after i washed the truck (got code 14). Now since then i have washed it again (now i get code 14 and 13) so i'm almost leaning towards both sensors being bad.(which seems really unlikely for them both to go at the same time like this)
    sorry for the rant but im not really sure what to do or where to go from here... im going to try and get to a dealership and attempt to talk to a diagnostic tech about this.
  6. May 22, 2011 at 3:58 PM
    Jerry Bear
    Jerry
    Mesquite, Texas
    2010 Access Cab
    Maybe there was water inside the sensors or in the sensor plugs or sockets.
  7. Jun 3, 2011 at 3:46 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    Only posting in case someone searches for this code and see's and see's this thread.
    My Light was on and off every other time i drove it for a day or 2, and it has been off since. I don't know what i did or if it was a fluke, but its off. I don't think the issue was water because i have driven it in the rain since then without the light coming on.
  8. Oct 22, 2011 at 2:25 PM
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    lights still been going on and off on me since i posted this, sometimes longer gaps in between lights than others. I brought it to Toyota a few weeks ago and they couldn't figure it out. Me and my friend worked on my truck for about an hour today and I'm pretty certain we fixed it. It turned out to be one of the crash detection sensors in the front bumper. Lights turned off right away with the new sensor installed.
  9. Aug 31, 2019 at 12:20 PM
    CaymanWest
    CaymanWest Member
    Cayman
    2005 Toyota Tacoma Red TRD Sport V6 Short Bed
    Pioneer AVH-4100NEX and rear-backup Camera
    I had the exact problem as described above by TheHansen and his solution worked perfectly for me as well. For anyone wanting the instructions for how to resolve this issue, I have documented them here.
