Airbag cover (rattle)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ekalb, Jan 6, 2010.
  1. Jan 6, 2010 at 8:06 AM
    ekalb
    ekalb [OP] Member
    Is there a way to remove the airbag cover on the passenger side of my 2003?
    There is a rattle in there that has gotten noticeably worse in the past few days and I would like to try and solve it. I would rather not blow my hand off in the process.
    Thanks
  2. Jan 6, 2010 at 8:08 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    the dash rattle is rather a regular occurrence in the 01-04s
    i think there was a dealer fix but ive found a folded up sheet of paper shoved between the dash and the windshield does wonders
  3. Jan 6, 2010 at 8:13 AM
    ekalb
    ekalb [OP] Member
    Does the cover pop off or is it fairly fixed in place?
  4. Jan 6, 2010 at 8:14 AM
    JimBeam
    JB
    2015 Tundra
    i have no idea as ive never tried to take it off
    im pretty sure tho its attached at either the top or bottom to prevent it from hitting your passenger in the face during a collision/airbag deployment
  5. Jan 6, 2010 at 8:55 AM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    The cover does not come off of the air bag. The whole unit is held in place with place with bolts, which can be tightened up to prevent the air bag from rattling.
    Take out the glove box, and look up. you'll see the bolts.
  6. Jan 6, 2010 at 5:43 PM
    ekalb
    ekalb [OP] Member
    Once I take those bolts out, will the cover and airbag assembly release through the top?
  7. Jan 6, 2010 at 6:11 PM
    kevhogaz
    SR5 PreRunner
    I think so. I'ts a been a long time since I've taken one out. We usually just tighten the bolt up, and call it good. Usually stops the rattle and the complaining from the customer at the same time.
    Remember you're playing with a small bomb, so please use common sense, and be careful. Either disconnect the battery, or unplug the air bag before you start messing around with it.
  8. Jan 6, 2010 at 6:44 PM
    ekalb
    ekalb [OP] Member
    Excellent, I will give that a shot.
    And yes, I was planning on disconnecting the battery, thanks for the heads up!
  9. Jan 6, 2010 at 6:52 PM
    IamJorgeEdward
    IamJorgeEdward Well-Known Member
    Jorge Edward
    Orlando, FL
    2015 Toyota Tacoma TRD Sport
    Completely stock
    well i have a similar problem but my rattle is coming from the steering wheel airbag.... how do i fix that
