Airbag Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dannyw, Nov 12, 2019.
  1. Nov 12, 2019 at 11:22 AM
    Dannyw
    Dannyw [OP] Well-Known Member
    Danny
    05 Tacoma
    I have a 2006 Tacoma, My airbag light is on, But also the light for the passenger air bag never changes. If someone is in the seat or not. I took the seats out and put dielectric grease on all the connects to make sure they were making good contact with no change. I get the light in the instrument cluster could be a clock spring but would that cause the passenger air bag always showing off??
  2. Nov 12, 2019 at 11:48 AM
    Muddinfun
    Muddinfun Well-Known Member
    I am 98% confident that if the airbag system detects a problem of any kind, it shuts down the entire air bag system and turns on the warning lights.
    LAMCKMA007 likes this.
  3. Nov 12, 2019 at 6:04 PM
    Dannyw
    Danny
    05 Tacoma
    Anyone else
  4. Nov 12, 2019 at 10:16 PM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    Muddinfun is correct. If there are any problems with the system the system will not function. I've replaced at least 40 air bags, most on Honda's and Acura's. Remove the ground, wait a few minutes, and reinstall ground. If that doesn't work it is a dealer repair (IMO).
    Muddinfun likes this.
  5. Nov 13, 2019 at 4:34 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Scan for which airbag code is setting off the light, OP. Many older code readers don't have airbag/ABS reading capability but perhaps an autoparts store can scan for you. It'll be specific with not much more guess work.
    For the record, my money is on the clock spring spiral cable as those are the most prone to failure on this system considering the age of the truck.
  6. Nov 13, 2019 at 4:38 AM
    LAMCKMA007
    San Diego county
    2006 DCLB 2WD
    That's cool they offer small hand held readers that'll diagnose air bags now. I didn't know that. Good info to know.
  7. Nov 13, 2019 at 4:44 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Yeah, Harbor Freight has a pretty powerful one I've been considering:
  8. Nov 13, 2019 at 7:20 AM
    Dannyw
    Danny
    05 Tacoma
    The horn on my truck doesn't work but the cruise control works. That is why I am thinking the clock spring, my cruise control is behind the actual wheel, But I would think it would also be attached to the spring.
  9. Nov 13, 2019 at 7:32 AM
    LAMCKMA007
    San Diego county
    2006 DCLB 2WD
    I could have REALLY used that "back in the day". Decent cost as well.
    DesertRatliff[QUOTED] likes this.
  10. Nov 13, 2019 at 7:43 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    SRS (air bag) light on and your horn isn't working? I'd hate for you to blindly throw (expensive) parts at it, but I'd bet a cold beverage it's the clock spring.
  11. Nov 13, 2019 at 8:58 AM
    Dannyw
    Danny
    05 Tacoma
    I have a clock spring ordered I will let you know how it turns out..
    Thanks
    DesertRatliff likes this.
  12. Nov 13, 2019 at 9:34 AM
    81shark
    81shark Well-Known Member
  13. Nov 13, 2019 at 11:53 AM
    Dannyw
    Danny
    05 Tacoma
    Nothing open but a label update for Child safety restraint
