Airbag light can't make up it's mind
Discussion in 'Technical Chat' started by lyndabean, Jan 25, 2012.
  1. Jan 25, 2012 at 8:32 AM
    lyndabean
    lyndabean [OP] New Member
    Linda
    Jacksonville, NC
    06 Tacoma Prerunner
    Every time I start my truck the airbag light goes off after it's self test and stays off as long as i don't drive away. As soon as I go about two or three feet it comes back on. It started when I had a cooler in the bed of the truck and had to stop suddenly causing the cooler to forcefully hit the back of the bed. The light came on shortly after that and has been doing this ever since. I don't want to go to a dealer because all the dealers around here are quick to rip you off by shotgunning their troubleshooting. Any suggestions?
  2. Feb 20, 2012 at 8:35 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    see if you can get a code and go from there
  3. Feb 22, 2012 at 11:36 PM
    Rmesa1
    Rmesa1 Well-Known Member
    Impacts can cause the occupant classification ecu to need to be recalibrated. Does he passenger seat belt light and airbag indicator still work properly when the airbag light is on?
  4. Feb 23, 2012 at 7:39 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    I have seen the plug behind the airbag "off" switch come loose, happened to me and was an intermittent light issue.
    Your impact of a cooler should have no bearing on this issue
