Airbag light fades on and off
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeWH, Sep 17, 2017.
  1. Sep 17, 2017 at 10:36 AM
    MikeWH
    MikeWH [OP] Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    I have 1996 Tacoma that is running good except- from time to time when I start it, the airbag light will be on, and stay on while driving. Other times it is off at first but comes on later. I figure this may be a wiring fault. But the weirder thing is it will sometimes slowly fade to off, then slowly fade back to on later. Other times it stays off as it should. There really is no rhyme or reason on when it goes on or off. I've tried correlating it to moving the steering wheel thinking it's related to a bad clock spring in there, but there seems to be no relationship.
    I'm having a hard time thinking the fading is related to wiring but I've never troubleshot this system before. Has anybody seen this, and if so were you able to fix it? Anyplace I should start looking? AFAIK the SRS system on this truck is a couple sensors under the hood, the SRS ECU, and the airbag itself (no passenger airbag or shutoff keyswitch on 1996). What other pieces should i look at?
    Thanks!
  2. Sep 17, 2017 at 10:45 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    This happens on my 95.5
    I think it has to do wth the clock spring
  3. Sep 17, 2017 at 10:57 AM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    I'm going to try the DTC procedure in the service manual where the module flashes the light to indicate problems. However I'm guessing it won't show anything because if there was a problem the light would stay lit (in theory)...
  4. Sep 17, 2017 at 11:05 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    the light must be on when you short the terminals, or else you won't get anything.
    For 1995-1997 tacomas, the SRS system consists of only a driver airbag (no seatbelt tensioners or crash sensors). So your problem can either be a bad clockpring (very common), a bad ECU or a bad airbag
    by the way, when the clockspring goes bad, it is usually accompanied by other symptoms such as horn not working and cruise control not working, and of course, the airbag light. If any of these symptoms occur when the steering wheel is turned, then it is definitely the clockpring
    if you manage to pull the codes, post the result, I might be able to tell you what is the problem
    jjsul likes this.
  5. Sep 17, 2017 at 11:22 AM
    onakat
    Canada
    2000 indestructaco!
    oh and check your battery, as a dying or malfunctioning battery can sometimes cause all sorts of weird problems. Since the SRS system counts on the battery to operate normally, a bad battery can cause the light to come on. Same for the alternator
  6. Sep 17, 2017 at 11:42 AM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    Horn and cruise work well which is why I haven't dug deeper on the clockspring front. Voltage slowly going up and down seems like it would point to the fading light. I'll stick my Fluke on it when I drive to work tomorrow and see if there is any correlation. Battery seems find (starts strong!) but alternator is original to the truck
  7. Sep 17, 2017 at 2:50 PM
    shawnster88
    shawnster88 Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    My 96 just started doing the same thing. I haven't really looked into it. Totally random.
  8. Sep 17, 2017 at 4:44 PM
    onakat
    Canada
    2000 indestructaco!
    Then there is a good chance the clockspring is not the culprit.
    Voltage spikes can be caused by either the battery or the alternator. Your alternator is 21 years old, so it wouldn't be a bad idea to check it (and the battery as well, just to be sure), to rule out any possibility.
    Or there is something inside the ECU, like a capacitor, that is failing. If it is the case, you will have to get the ECU replaced. Unfortunately, a random SRS light is also a symptom of this :/ But let's hope it is not
    jjsul likes this.
  9. Sep 17, 2017 at 6:22 PM
    jjsul
    James
    New Hampshire
    95.5 OME
    My horn and cruise work as well.
    I replaced my battery two years ago, guess I could check that and the alternator. Lemme find out how :anonymous:
  10. Sep 17, 2017 at 6:48 PM
    Glamisman
    Glamisman Well-Known Member
    check the charging voltage, like mentioned earlier if it spikes it causes problems. Do the headlights at night get visibly brighter when you rev the motor?
  11. Nov 6, 2019 at 3:57 PM
    elreyjr
    elreyjr Member
    Hello, I am new at this site. I have a 1995 Tacoma with the exact same issue. Did you ever find out what was the problem? Any help is greatly appreciated. Thank you.
  12. Nov 6, 2019 at 6:04 PM
    857975wstbygd
    857975wstbygd Wv Taco
    Putnam, WV
    2016 White TRD OR
    Stock
    Mine does the same thing
  13. Nov 7, 2019 at 1:51 PM
    shawnster88
    Shawn
    Same here in my 96
  14. Nov 13, 2019 at 8:03 AM
    elreyjr
    elreyjr Member
    Hey guys, for all of you out there. I found the problem to the issue above. It's the SRS Airbag Control Module. I decided to repair it myself since they are very expensive. I'll post some pictures once I receive the part I need to fully repair it.
    homegrown_xt likes this.
  15. Nov 13, 2019 at 8:46 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    In September, after sitting in the sun all day windows up on a 95-100 degree day, my A/B light (1995.5 model) started coming on, fading, etc without the key even in the ignition. Makes sense that it can since the clockspring has power with ignition key in off position.
    I tried disconnecting/reconnecting the battery, but it would still come on, fade in and out, be off, then on again the next morning. I did nothing more and it went away after about 4 days. Hasn't happened since.
  16. Feb 29, 2020 at 1:08 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I have a long shot here, mine just started doing it after I had the lower dash panel off wiring up an aux. switch for some lighting. The srs light would be on constantly so I disconnected the battery and unplugged and plugged in all the connectors going to the srs system and made sure that they were clean connected properly and checked all other wiring under the dash. I retraced my steps of major things that I have done to my truck within the last 6 months, namely putting in the Scangauge which uses my obd2 port and going to led lights on the exterior. I unplugged the scangauge from the obd port and the light didn't come on and when I plugged it back in it would come on and then fade off. I am thinking the scanguage holds a little residual power and lights up the srs light for a few seconds and shuts off.
    Keeping an eye on it.
    Update: 8/28/2021, my solution is on post #22, still keeping and eye on it.
  17. Sep 21, 2020 at 8:34 PM
    petercrapsodt\y
    petercrapsodt\y Member
    1995 Tacoma 4WD Xtracab
    Not to bump this old thread... But I have the same issue. I suspect it's electrical, however, since it seems to coincide with the clock going dark or coming back on. It all started when I put a phone a charger in the cig lighter. Shortly afterwards, the clock went dark and the airbag light started flickering. I swapped out new fuses and it seemed to be fine after that (though the old fuse seemed to be fine too).
    Anyway as a test, I tried putting a charger into the cig about a month later and it started back up again. It definitely seems that the clock and the airbag sensors are related in some way.... If anyone has any theories, it would be greatly appreciated!
  18. Jan 5, 2021 at 3:39 PM
    BrotherJohnny14
    BrotherJohnny14 Well-Known Member
    Johnny
    Virginia
    1995 Tacoma extended cab SR5
    So I actually had to have my horn worked on about 3 years ago but I don’t think it was replaced I think it was just some wires messed up. However right around the same time my air bag lights started flashing on and off sometimes dim randomly. Does that sound like the clock spring itself or maybe just wiring somewhere?
  19. Jan 10, 2021 at 1:52 PM
    petercrapsodt\y
    So I think I fixed it.
    The cigarette lighter wiring had some wiring go bad and that was shorting out a lot of the electrical. I pulled the lighter and had it re-wired and ever since then, the lighter works, the clock stays on consistently every time and there's been no flickering/faded SRS light either.
    Fingers crossed that was the only culprit.
  20. Jan 10, 2021 at 3:07 PM
    BrotherJohnny14
    Johnny
    Virginia
    How much work was it to do that? My clock used to come and go as well just like the airbag light I’m wondering if I should look into that as well
