Airbag light on 01 PreRunner
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sixgun, May 11, 2011.
  1. May 11, 2011 at 11:04 AM
    Sixgun
    Sixgun [OP] Well-Known Member
    Mobile, Alabama
    2024 DCSB TRD OR
    I've had my airbag light come on and would like to know how to get it checked aside from the stealership. The closest one is almost an hour drive and I don't want to pay $75 for them to pull a code. Is there a way I can jump a connector and get count? Any link to SRS code #'s?
    Thanks
  2. May 11, 2011 at 11:09 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Autozone, Advance Auto parts, places like that typically checks codes for free.
  3. May 11, 2011 at 11:19 AM
    Sixgun
    Mobile, Alabama
    2024 DCSB TRD OR
    They can only do CEL and ABS lights. Called Eastern Shore Toyota and they wanted $95 b/c it's not 2yrs old or newer...:mad:
  4. May 11, 2011 at 11:24 AM
    sxgt
    sxgt Member
    03 DC SR5 4WD TACO
    I have an 03 with Airbag lights on. I was able to get my codes pulled by my local mechanic (not a toyota tech) - pretty sure he used a SnapOn code reader. He could only read and reset it with that tool - there was no further diagnosis from the reader - it just gave the codes.
    You might check craigslist for someone close by that was/is a toyota tech on the side - they ususally have access to the toyota laptop scanner tool.
  5. May 11, 2011 at 11:38 AM
    Sixgun
    Mobile, Alabama
    2024 DCSB TRD OR
    Called Toyota of Mobile, $45. Also found a local tech that's willing to run the code for $35. There has go to be an easier way to do this... A connector jump, count flashes.. It's a lot of money for 5mins of their time.
  6. May 11, 2011 at 4:16 PM
    01Tac0ma
    01Tac0ma Bash Fabriction & Off-Road
    Chad
    West Columbia, SC
    SAS 01 TRD 4x4
    Look at build!
    Check to make sure all your wires are plugged up to especially if you just had teh dash out for any reason, maybe a connecter has a bad connection or is just simply unplugged.
  7. May 11, 2011 at 4:28 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    My 1999 did the same thing. I found via interweb, to pull both of the 12 V acc plugs from underneath ash tray, remove battery sit down have a beer or six, plug 12V acc back in and re-connect battery and the light goes off, I have done this twice. I have no idea why it went off but I was using a 1 million candle power light through the 12v acc plugs and trying to charge cell phone at the time.
  8. May 12, 2011 at 8:40 AM
    Sixgun
    Mobile, Alabama
    2024 DCSB TRD OR
    Thanks Monkey, I'll give that a try. I found the FSM linked through couple older posts and after digging around I found some helpful pages. Below are some links to help the next guy that comes along with an SRS issue.
  9. Jun 12, 2011 at 7:59 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    wher exactly are these plugs exactly?
  10. Jun 14, 2011 at 5:49 PM
    Monkeysuncle
    Kevin
    Florida
    right below ashtray I had 2 12v aux outputs so one day I tried to charge cell and run a spot light. Air bag light came on. I took center console apart and un plugged the two 12 v plugs from factoey harness just below the ash tray and didn't touch the abs (yellow) wires. Took battery off . Reinstalled the two 12v wires to the outlets and then battery, and no abs or airbag light.
  11. Apr 2, 2012 at 4:01 PM
    Tashier
    Tashier Well-Known Member
    Sean
    Beaverton, OR
    99 Tacoma V6 Limited
    Air Bar Suspension
    Good thread. Thanks for those links.
