Airbag light on after stereo install
Discussion in 'Technical Chat' started by HeadlampRevamp, Mar 13, 2010.
  1. Mar 13, 2010 at 10:05 AM
    HeadlampRevamp
    HeadlampRevamp [OP] Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    It was a clean install, all wires were soldered and taped. I currently have the door panel off to install some door speakers. I had to run to the store and noticed that the airbag light is on. What did I do during the installation process to make the airbag light come on?
  2. Mar 26, 2010 at 4:03 PM
    DavidT
    DavidT D
    Pensacola, FL
    2013 Tacoma x-runner
    did you take off the drivers seat?
  3. Mar 26, 2010 at 6:54 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Removing the driver's seat wouldn't have any relation to an airbag light on a pre-2005 Taco.
    Odds are the stereo installation work screwed with some of the wiring / connections behind the lower center dash, where the SRS controller (and a lot of the central SRS wiring) is located.
    If you tapped into a wire for illumination without knowing exactly what it was and / or how the Taco dimmer system is laid out, that would be a likely culprit for electrical weirdness like this.
  4. Jul 24, 2010 at 9:14 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Did you get this figured out, and if so what was it?
  5. Jul 29, 2010 at 5:47 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    If the on/off switch is unplugged, the SRS computer sesnes a problem, and will turn on the light. It thinks there is an open circuit in the system.
    Nice thing about airbags? They self check, so the truck will tell you if the problem is fixed or not. If the light goes off, you're good to go.
  6. Jul 29, 2010 at 5:55 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    my light went off about two days after the install
