airbag light on, and no cc or horn?
Discussion in '1st Gen. Tacomas (1995-2004)' started by newskooler, Feb 23, 2011.
  1. Feb 23, 2011 at 4:22 PM
    newskooler
    newskooler [OP] Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    hey guys just finished the removal of my body lift. it was alot more work than i expected but only took 6 hours (mostly by myself). it drives great. my shifter is at about the same level as my climate controls, i just need a skull shifter and some moonies and i can say i have the first 4wd rat rod taco lol.
    anyways somewhere along the line i foregot to undo the battery(not sure that it matters) and now my airbag light is on and i dont have cruise control or a horn. :confused: any ideas?
  2. Feb 23, 2011 at 5:17 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    That combination of symptoms suggests something wrong in the vicinity of the spiral cable (in the upper steering column).
  3. Feb 23, 2011 at 5:28 PM
    newskooler
    Nick
    Lake Shastina,ca
    any idea how/where to get it and any idea on cost? i was reading about it for the 2nd gens and theyre upwards of 250 bucks?
    yes i had to remove the exstension from inbetween the linkage and shaft.
    agreed
  4. Feb 23, 2011 at 5:36 PM
    newskooler
    Nick
    Lake Shastina,ca
    im pretty sure that at one point my girlfriend turned the steering wheel while i was finishing up putting the bumper on. how do i check this clock spring?
  5. Feb 23, 2011 at 5:55 PM
    newskooler
    Nick
    Lake Shastina,ca
    damn that just sounds expensive. i guess the search is on. would that cause all three of those to fail though?
  6. Feb 23, 2011 at 6:02 PM
    newskooler
    Nick
    Lake Shastina,ca
    damn technology. thanks man
  7. Feb 23, 2011 at 8:20 PM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Yep - spiral cable = 'clock spring' (so-called because of the spiral wiring). It's what keeps your upper steering column electrical controls (and the airbag) connected while the wheel is turning from side to side.
  8. Feb 23, 2011 at 9:15 PM
    newskooler
    Nick
    Lake Shastina,ca
    haha its alright i ripped her mirror off...twice. seriously who makes no collapsible mirrors
  9. Dec 1, 2011 at 1:31 AM
    DIRT YOTA
    DIRT YOTA Aka EL ROJO
    Cory
    Camarillo, CA
    03' dbl cab with some stuff
    Dam my airbag light is on, no horn and no cruise control!!! Ahhhhh!
  10. Dec 1, 2011 at 2:53 PM
    newskooler
    Nick
    Lake Shastina,ca
    most likely the clock spring man.
    have you had your steering disconnected? its a fairly easy fix just 1disconnect the battery,
    2 wait a while,
    3 remove the steering wheel and airbag,
    4 then the yellow and black circle thing(clockspring/spiral cable),
    5 then install in reverse order.
    its not cheap, roughly 300bucks
  11. Dec 1, 2011 at 8:26 PM
    Gorillazrus
    Gorillazrus To be continued...
    01 Prerunner SR5
    5100 Bilistens set @ 1" in front, Wheelers 5 leaf in rear, Leer Topper, TRD Skid Plate, Dual Band Ham Radio
  12. Dec 1, 2011 at 8:39 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 8000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    I just had my airbag light come on a week ago. Had the dealer check it with there computer. Clock spring needs to be replaced. Clock spring is around $375.00 and labor is right around $100.00
  13. Dec 2, 2011 at 9:07 PM
    newskooler
    Nick
    Lake Shastina,ca
    gorillasrus- thats exactly what I did, got mine for 50 but had to drive to oregon to get it.
    Marshbuster- you should save yourself the c note and rent a steering wheel puller from autozone and do it
    yourself. I dont think they even charged me to use the tools. The job takes an hour at the most. most of the time was after I pulled the battery cause I wanted to make damn sure the charge to the air bag was gone.
  14. Dec 3, 2011 at 12:33 AM
    DIRT YOTA
    Cory
    Camarillo, CA
    I'm gonna have to look into this....had my rack bushings replaced and shaft slip joint tack welded to get rid of that clunk, but that was a while back. Weird it just now went out.
  15. Dec 12, 2011 at 10:51 AM
    beerye
    beerye Steel Curtain!!
    Brian
    Tucson, AZ
    02 TRD 4x4 5spd
    3" suspension lift 2009 Tacoma Alloys K&N Intake
    Did a new rack last week and didn't know about this so called "clockspring" and apparently the wheel turned at somepoint, and it snapped while I was driving. So now I have an airbag light on, no CC, and a horn that only works when I don't really need it to lol.
    Wish I could find it for that cheap!!!
    Nice Link for the DIY!
  16. Dec 12, 2011 at 11:08 AM
    wesrunner
    wesrunner Team 4Runner
    Wes
    Louisiana
    It's paid for.
    1999 T4R 4WD V6, Deck plate, B&M trans cooler, LED guages and dome lights, LED reverse lights, 2.5" spacer lift, highway tires.
    I broke mine too! :D
    I have to get it fixed... Though I never had an airbag light... I guess my 99 dash didn't come with one? No tach either. just a base dash...
    Am i right?
  17. Aug 16, 2012 at 10:34 AM
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    Just ordered up my clock spring (or "spiral cable" as Toyota calls it) due to the fact that cruise control stopped working, airbag light came on, and horn stopped working. Got it from the dealer at my cost for $221.58! :eek: Damn, these things aren't cheap!
