Airbag light on, can't shift from park.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MnToyGuy, Mar 14, 2015.
  1. Mar 14, 2015 at 10:26 PM
    MnToyGuy
    MnToyGuy [OP] Well-Known Member
    Eric
    Minneapolis
    2012 TRD sport
    Was trying to wire in an LED light bar. Relay triggered (negative) off of the under hood HB circuit. Fed the POS primary and secondary LED's in the switch from IGN and taillights with an ADD A FUSE. Works fine, but now the AB light is lit and can't shift out of P.
    Anyone know how to reset?
  2. Mar 14, 2015 at 10:32 PM
    Digital Louie
    Digital Louie Member
    2007 Tacoma TRD 4.0L
    Just happened to me with a Yaris and an Alternator change. Check your main fuse link 120 Amp. Mine was blown. 15 buck from a dealer and I was fixed. Same exact error lights as you, but on a Yaris. I assume you didn't pull the battery as I didn't.
  3. Mar 14, 2015 at 11:02 PM
    MnToyGuy
    Eric
    Minneapolis
    2012 TRD sport
    The fusible link? It starts and runs fine. I found the trick of the button in front of the shifter to be able to shift, but too late to try taking a spin. AB light still on.
    Gotta love the internet and forums with good people. How FUCKED would we all have been 20 years ago?
    Thanks so much!!
  4. Mar 15, 2015 at 5:38 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the IGN 1 fuses # 1 and # 2. More than likely one of them are blown.
    They are inside behind the coin tray to the left of the steering wheel.
  5. Mar 15, 2015 at 6:07 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yep, gonna be one of those fuses. I bet you don't have tail or brake lights either.
  6. Mar 15, 2015 at 11:13 AM
    MnToyGuy
    Eric
    Minneapolis
    2012 TRD sport
    Both IGN fuses are fine, have tail and break lights. Any other ideas?
  7. Mar 15, 2015 at 11:46 AM
    MnToyGuy
    Eric
    Minneapolis
    2012 TRD sport
    Problem found. The IGN1 10A in the second row middle was out. I just checked the 2 on the left.
    THANKS SO MUCH GUYS!!
  8. Mar 15, 2015 at 7:16 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    We have all been there. Glad you got it. I knew it had to be one of those.
