Airbag light on dash illuminated
Discussion in '1st Gen. Tacomas (1995-2004)' started by Funkensour, Aug 21, 2019.
  1. Aug 21, 2019 at 3:03 AM
    Funkensour
    Funkensour [OP] Well-Known Member
    Vincent
    Columbus, OH
    2004 Prerunner SR5 Tacoma 2WD
    scion xb seat swap/ 3rd gen 4 runner swap in progress
    Hi all I've owned my 04 prerunner for about 5 months and when I started her up tonight leaving work the airbag light came on for the first time and stayed on the whole ride home. My front passenger side seat is unbolted from the mounts. But there are no wires connected. Should I be worried
    I've been in progress of swapping seats, the scions need more work than I expected, going to try 4runner seats. Bolting the stock seats back in for now
  2. Aug 21, 2019 at 8:02 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Take it to the dealer. Usually best to let them deal with SRS fault codes.
  3. Aug 21, 2019 at 10:26 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Most likely just a clock spring, but let the dealer check it out.
  4. Aug 21, 2019 at 6:09 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    well, if you want to know what's wonrg with the SRS(airbag) system, you have to pull the error codes. YOu can do this with a SRS capable scan tool or by shorting the Tc and E1 pins together in the DIAGNOSIS port in the engine bay, near the intake. Diagram of pins is inside the cover when you flip it open. The light will blink in a pattern, telling you the code
  5. Aug 23, 2019 at 8:41 AM
    patoeknee
    patoeknee Member
    Tony
    2003 Tacoma 3.4L Offroad 274,000 5-spd manual Xtra cab
    My airbag light went on after a stall/failed-start/start sequence at a traffic light. Disconnecting battery overnight and clearing the codes did not clear the light.
    I took it to a dealer, they ran through the troubleshooting procedure, which mostly involved a couple hours of unplugging and plugging the various components of the SRS system. That process must have reset something, as they found nothing wrong and the light went out. That was 10 years ago and have had no problems since.
  6. Sep 11, 2019 at 1:10 PM
    Funkensour
    Vincent
    Columbus, OH
    update
    code is B0101 "open in D squib circuit
