Airbag light on! Y? no airbags went off ! hmmm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stinky_truck, Sep 11, 2010.
  1. Sep 11, 2010 at 6:01 PM
    stinky_truck
    stinky_truck [OP] Well-Known Member
    ryan
    i=13 miles currently @ 75,500 miles
    Plane Jane:4x4,6 speed, shortest bed,URD3SC
    front baja bbq hoop bumper and rear allpro bumper, URD SCIII,urd short throw & stg IIIclutch combo kit w/throwout, DDM Hid 4000k, icon frt (coil overs)& rear shocks (piggy back rez)& add a leaf.
    :confused: my airbag light is on! Y? no airbags ever deployed. i was in an accident 8 months ago. :( y act up now? help me out. anybody ever have this problem?
    _stinky ghetto truck
  2. Sep 11, 2010 at 6:03 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    check your fuses...did you do anything like install a new stereo or anything?
  3. Sep 11, 2010 at 6:04 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Most likely a broken clockspring which means your airbag won't deploy in an accident.
  4. Sep 11, 2010 at 6:09 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    i had my airbag light on and it was from a unplugged connector in one of the door panels. something to do with the seatbelt pretensioner. maybe check that out?
  5. Sep 11, 2010 at 6:10 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Do the people that fixed you truck have a liftime warranty? When I got my truck fixed they told me if there is anything wrong to bring it back to them (Of what they were suposed to fix).
  6. Sep 12, 2010 at 11:43 AM
    Taco93
    Taco93 Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
  7. Sep 12, 2010 at 11:47 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The airbag light means something is wrong with the aigbag system....Not that they have deployed. So you need to check the connectors under the seats, thru the doors, to the sensors, check the clockspring in the steering wheel, and continue from there...
    It could be related to your accident- so it might be worth checking with the company that did the repairs about it...See if it might be covered....
  8. Oct 16, 2010 at 12:44 PM
    Ray07tacoma
    Ray07tacoma Well-Known Member
    Ray
    Phoenix
    07 Tacoma access 4x4
    turbo KN Filter 3" Lift Kit Rock Sliders TRD Skid plate ProComp 285/75R16, Removed. FJ Wheels w/ 265/70R17 Delay wiper switch 168xxx miles, engine lost compression at cyl 1. Replaced with pulled engine with 63k miles (non Turbo).
    I had been wrestling this for the last 2 months. It is not just a nagging warning light, more important is that your airbags might not deploy in an accident.
    The only special tool required to remove the clockspring is a wheel puller and once out you can check the continuity of the cable with a ohm meter. From the multiple post and from what I saw of this part, this is probably 90% of the warning light issues.(10 minutes procedure)
    ck this post:
    http://www.tacomaworld.com/forum/te...ing-airbag-light-post2285436.html#post2285436
  9. Oct 16, 2010 at 12:47 PM
    xroller
    xroller Blowin by em sideways
    X-roller
    Albuquerque New Mexico
    2006 Toyota Tacoma Xrunner Speedway Blue
    1 hp mod
    I had mine turn on because I disconnected the plug where you can put the key in it to turn it on and off.... I just turned the airbag off started the truck and the light was gone.... I turned the airbag back on and it was still off.
  10. Oct 16, 2010 at 12:52 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    none of that in a DC
  11. Oct 16, 2010 at 12:56 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Mine is finicky with my car starter. Sometimes when I use the starter function the airbag light comes on till I turn the truck off and on again.
